[postgis-users] Updated shapefile to update postgres database
Paragon Corporation lr at pcorp.us
Sat Jun 7 13:17:46 PDT 2008
Here is a thought, but not sure how slow this will be
DELETE FROM mystreets_table
WHERE street = 'N/A' AND
EXISTS (SELECT n.street FROM mystreets_table n  WHERE (n.street <> 'N/A' AND
n.street > '')  AND ST_Equals(n.the_geom, mystreets_table.the_geom))
The st_equals might be better to replace with ~=  if you want to match exact
vertices.  I presume ~= is actually more efficient
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of SenTnel
Sent: Saturday, June 07, 2008 2:25 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Updated shapefile to update postgres database
Hello! Im confused about this issue:
I have a street (polyline) duplicated, one on top of the other, exact same
features, same "the_geom", but one bears the street name (column:"street")
"main street" and the other bears "N/A" as street name. Now my maps shows
the street but the name that shows is "N/A", and I would like to delete the
"N/A" polyline, how can i do basically this:
delete from mystreets_table street = 'N/A' where 'N/A' = street 'main
street'.the_geom (delete from mystreets table the street named 'N/A' where
the_geom in 'N/A'
equals the_geom in street "main street") another words, delete only the N/A
streets that the_geom is same as "main street", I hope you understand,
Thanks!
SenTnel wrote:
> Thanks Regina, Chris and all of you for your help. Im truly newby but
> with such help Im ready to start the procedures, Ill keep you posted
> of my progress or else if some issue comes along that may require some
> light from you, Thanks again and I hope my problem/solution may be of
> help to many others,
> Thanks again!
> SenTnel wrote:
>> Hello!
>> I would like some help updating a postgres database. This is the problem:
>> We created the database using shp2pgsql to convert a shapefile that
>> contains a city's street details (centerline), after we created the
>> database we also created an aditional column to classify the street
>> types
>> (eg: street, avenues, highways, etc.), now we are working on the
>> original shapefile, updating new roads, changes made to highways due
>> to constructions modifications, etc., and we want to upload the "updated"
>> shapefile, without afecting the actual database, another words, we
>> would like to convert to postgres the updated shapefile with the new
>> information (it cuold be the whole shapefile) but to keep the added
>> clasiffication column intact. How can we do that?
>> Thanks
View this message in context:
http://www.nabble.com/Updated-shapefile-to-update-postgres-database-tp170535
62p17705777.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
