[postgis-users] Maximum z-Coordinate
Andy Anderson aanderson at amherst.edu
Mon Jun 9 07:18:15 PDT 2008
Use ST_ZMax(box3d) on the set of multipolygons.
-- Andy
On Jun 9, 2008, at 8:17 AM, Max wrote:
> Hello,
> i'm using postgis to store 3D multipolygons and i want to get the the
> maximum z-corrdinate of a set of multipolygons. Right now i first
> create
> a set of polygons which contains the polygon from all multipolygons,
> then i create a set of points from the polygons and at the end i loop
> through the points to calc the maximum, but i think this way is
> slow, so
> i want to know if there is an other way, f.e. is there a way in
> postgis
> to extract all points from the multipolygons with one function.
> Hope someone can help me.
> thank you in advance
> best regards
> max
> postgis-users mailing list
