[postgis-users] Re: pgrouting and postgis
Daniel Kastl
orkney at gmx.de
Tue Jun 10 17:14:58 PDT 2008
Hi Daniel,
Maybe http://pgrouting.postlbs.org/discussion is the better place for
this question.
That kind of error happened in a previous version of pgRouting, and I
thought it has been solved.
I never tried pgRouting on Gentoo Linux, so it could be a distribution
issue. If something is wrong with the data, it would help you could try
it with another Linux distribution.
In that case you could file a bug report (tickets) on the pgRouting site
(you need to register an account for that) and we will try to solve the
problem?
Daniel
PS: if the data is not too large, could you send me some of your data
for testing?
Daniel W schrieb:
> Hello.
> Maybe it will help. I found these logs, if I do the query:
> terminate called after throwing an instance of 'std::bad_alloc'
> what(): St9bad_alloc
> LOG: server process (PID 13657) was terminated by signal 6
> LOG: terminating any other active server processes
> WARNING: terminating connection because of crash of another server process
> DETAIL: The postmaster has commanded this server process to roll back
> the current transaction and exit, because another server process
> exited abnormally and possibly corrupted shared memo
> ry.
> HINT: In a moment you should be able to reconnect to the database and
> repeat your command.
> LOG: all server processes terminated; reinitializing
> LOG: database system was interrupted at 2008-06-10 22:52:32 CEST
> LOG: checkpoint record is at 0/37D04360
> LOG: redo record is at 0/37D04360; undo record is at 0/0; shutdown TRUE
> LOG: next transaction ID: 1883985; next OID: 2550772
> LOG: database system was not properly shut down; automatic recovery in progress
> LOG: record with zero length at 0/37D043A8
> LOG: redo is not required
> LOG: database system is ready
> greets,
> Daniel
> On Tue, Jun 10, 2008 at 6:26 PM, Daniel W <gentoo.murray at gmail.com> wrote:
>> Hello,
>> i am new to Postgis and pgRouting and i am trying to route over some
>> data, but it doesnt work for me.
>> I installed a routing database with following commands as described in
>> the pgrouting online tutorial
>> (http://pgrouting.postlbs.org/wiki/Workshop-CreateRoutingDatabase).
>> The data, which i want to use for routing, I got from the
>> Openstreetmap projekt. I wrote me a program, which parse the xml file
>> and write the data in a database.
>> My Table with the name "subways" was created with the following command:
>> CREATE TABLE subways (ID integer , startNode integer REFERENCES
>> nodes(ID), endNode integer REFERENCES nodes(ID), cost double
>> precision, name char(40), x1 double precision, y1 double precision, x2
>> double precision,y2 double precision, PRIMARY KEY(ID, startNode,
>> endNode));
>> And the table looks like that:
>> id= way id
>> name = name of the street
>> startnode, endnode are the IDs of the nodes
>> x1,y1 are the coordinates of the startnode
>> x2,y2 are the coordinates of the endnodenode
>> cost = length of the way
>> id | startnode | endnode | cost |
>> name | x1 | y1 | x2 | y2
>> 0 | 140530 | 140555 | 8.5403091715829 |
>> | 8.3889675 | 53.0587826 | 8.28445 |
>> 53.1030248
>> 2 | 206374638 | 26870008 | 0.320998562351643 |
>> | 8.2145964 | 53.1430959 | 8.2168197 |
>> 53.1405356
>> 3 | 201754820 | 92909800 | 0.172230180241359 | Industriestraße
>> | 8.1939216 | 53.1498095 | 8.1965042 |
>> 53.1497966
>> 5 | 26869963 | 165748872 | 0.0268226987132517 |
>> Heiligengeistwall | 8.2087014 | 53.1412273 |
>> 8.208876 | 53.1414446
>> 6 | 165748872 | 26869964 | 0.0208274380181027 |
>> Heiligengeistwall | 8.208876 | 53.1414446 |
>> 8.2090004 | 53.1416164
>> (In another Table named nodes, i have every Point-ID with coordinates)
>> If I try now the routing function A-Star.....
>> SELECT * FROM shortest_path_astar('SELECT id, startnode as source,
>> endnode as target, cost, x1, y1, x2, y2 from subways', 31567898,
>> 96012788, false, false);
>> ... I get following error code:
>> server closed the connection unexpectedly
>> This probably means the server terminated abnormally
>> before or while processing the request.
>> The connection to the server was lost. Attempting reset: Succeeded.
>> I hope you can help me, my system is:
>> Gentoo Linux 64 Bit
>> postgresql 8.0.15
>> postgis 1.3.1
>> pgrouting 1.02
>> Best regards,
>> Daniel
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
