[postgis-users] GROUP BY geometry dropping points
Martin Davis mbdavis at refractions.net
Fri Jun 13 13:18:31 PDT 2008
Since GROUP BY is using the BB, it seems like it would be independent of
line orientation.  Of course, it will also have the problem that a line
BB might include other completely different lines...
One idea we used here was to GROUP BY the WKB text for the geometry.
That works well for points, but of course will require same orientation
for lines. (But the normalizing idea I suggested would take care of this).
If this data was in BC-Albers then 1.5 mm is probably below the
threshold for the floats in the BB.  So that is likely the problem.
Martin
Dan Erikson wrote:
> Thanks Martin, that is good to know.  I was assuming that the GROUP BY
> operation was based on the actual geometry, not the bounding box.  If
> it is using the bounding box, do you know if it considers direction on
> a line geometry?
> Nearest point was about 1.5 mm away.  As you are aware with our
> "clean" process, we're likely to have many points and line strings
> that are very close.  Seems like this was the problem in the
> polygonize process as posted yesterday.
> Dan Erikson BNRSc
> Project Manager
> Timberline Natural Resource Group
> (250)-314-0875 ext 240
> #201-175 4th Avenue  Kamloops  BC
> www.timberline.ca
> Martin Davis wrote:
>> One thing I do know is that GROUP BY (and probably DISTINCT) use only
>> an approximate bounding box test when comparing geometries.  The
>> reason for this is that the equality operator used only checks the
>> bounding box, and the BB is defined using floats, not doubles.  We've
>> had issues in the past where points which are very close together get
>> partly ignored when using GROUP BY.
>> For the missing point, is there some other point very near it?
>> IMO this is not good behaviour to have in PostGIS.  It's very useful
>> to use GROUP BY and DISTINCT in these kind of situations, but you
>> need to have exact answers.  I suggest that the equality operator be
>> modified so that for small geometries (Points and 2-point linestrings
>> at least - and perhaps boxes) it tests the exact vertex values.
>> Dan Erikson wrote:
>>> I have a point dataset that I am looking to pull unique geometries
>>> from.
>>> I have tried the following:
>>>     * select geom from foo GROUP BY geom;
>>>     * select DISTINCT geom from foo;
>>> Both of these methods result in at least one point dropped that
>>> should not have been.  The point dropped in error was not a
>>> duplicate point.  It in fact was already unique in the table.
>>> This method seems to work:
>>>     * create temp table bar as select * from foo;
>>>     * delete from bar where st_equals(a.geom, b.geom) from bar a, bar
>>>       b and a.gid < b.gid;
>>>     * I know this is a round-about way, but it proves that GROUP BY or
>>>       DISTINCT should have worked.  (I think)
>>> Any ideas why group by is seemingly erroneous?
>>> Dan Erikson BNRSc
>>> Project Manager
>>> www.timberline.ca
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
