[postgis-users] where to register to submit bug?
Dave Fuhry
dfuhry at gmail.com
Sat Jun 14 11:15:50 PDT 2008
Mark,
I'm beginning to wonder if the stricter-EWKB-parsing patch applied
in November was a mistake.
I have an app which bulk-loads shapefiles (of varying quality),
then "repairs" or NULLs geometries which are not isvalid(). I'm not
finding a good way to bulk-load input data when the dataset has a
record which causes:
ERROR: geometry contains non-closed rings
COPY (shp2pgsql -D) is out, since COPY aborts on error. From
discussions on pgsql-dev, it is not clear whether COPY will support a
"SKIP ERRORS" or "ERRORS TO error_table" clause anytime soon. Even in
that case, I would like a convenient way to keep the table's other
(non-geometry) attributes.
For shp2pgsql's insert-statement mode, records are grouped into
250-record batches surrounded by BEGIN; ... END;, so an erroneous
record will abort the 250 records in its batch. Removing transactions
entirely is no good for bulk-loading, since the database will be
forced to commit every record to disk before processing the next.
Another option would be to move EWKB parsing logic to shp2pgsql so
that shp2pgsql can decide how to handle erroneous geometries. This
option seems ugly and redundant to me, although I'll defer judgement.
Lastly, maybe some per-session option to allow postgis to import
erroneous geometries is in order. Then they can be corrected in a
controlled fashion by isvalid() queries. I'm somewhat preferential
towards the geometry processing functions (in the below example,
st_simplify()) being robust in the face of questionable geometry
anyway. Thoughts?
Thanks,
Dave
On Sun, Dec 2, 2007 at 5:58 PM, ivan minčík <ivan.mincik at gmail.com> wrote:
> Thanks, I hope it will help to others...
> Mark Cave-Ayland wrote:
>> On Sat, 2007-11-17 at 20:34 +0000, Mark Cave-Ayland wrote:
>>> So the real bug in this case is that the (E)WKB parser doesn't seem to
>>> attempt to validate any geometries being passed through it :( I've had
>>> a look at the parser code and it's quite a complicated beast with not
>>> many comments, so I imagine a fix is going to a little time to come up
>>> with.
>> FWIW I've now committed a patch to SVN to include simple validation for
>> geometries being input in (E)WKB format. From latest SVN:
>> bug=# select
>> astext('010600002011080000040000000103000000010000000400000052B81E855E5914C100000040E96133C1EC51B81EA35914C1E17A146EE76133C18FC2F5289E5914C114AE47E1D76133C15C8FC2F58D5914C114AE4761C16133C10103000000010000000500000066666666805914C11F85EB51DB6133C133333333835914C11F85EB51E46133C166666666645914C152B81E05E56133C100000000625914C1EC51B81EDC6133C166666666805914C11F85EB51DB6133C10103000000010000000100000048E17A14555914C166666666C26133C1010300000001000000010000001F85EB51565914C1EC51B85EC66133C1'::geometry);
>> bug=#
>> Hopefully this means future releases will prevent these ill-formed
>> geometries getting into the database in the first place when inserted as
>> (E)WKB.
>> Kind regards,
>> Mark.
> postgis-users mailing list
