[postgis-users] Updated shapefile to update postgres database
Paragon Corporation
lr at pcorp.us
Sun Jun 15 02:51:27 PDT 2008
Take a look at our article on the subject if you haven't already.
It covers how to create gist and btree indexes
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01
Samples exist in the postgis docs too.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of SenTnel
Sent: Sunday, June 15, 2008 4:37 AM
To: postgis-users at postgis.refractions.net
Subject: RE: [postgis-users] Updated shapefile to update postgres database
Thanks Regina for your help! I must tell you that the worst part of this is
not knowing what most of what you tell me means! :confused: Im trying to
become familiar with this but don't know much... Totally ignore btree, gist
index, but I'll google it to see what I can find. As far as the
configuration it is the installation's default, suggestions are welcome!
=^D
... again... Thanks!
Paragon Corporation-2 wrote:
> It shouldn't take that long I don't think. 123,000 records is not a lot.
> Granted this is a suboptimal delete.
> First thing to verify
> 1) Make sure to have a btree index on street
> 2) I assume you have a gist index on your the_geom field already. If
> not that could be the culprit.
> 3) What are your postgresql.conf settings like for work_mem etc. If
> these are at there defuats, then that would be a problem too.
> The other alternative is to do with an IN instead of an EXISTS. That
> would at least not be correlated, but I'm not clear if an
> the_geom IN (SELECT ....)
> Would match up correctly since I suspect it may use = for compare
> Hope that helps,
> Regina
> SenTnel
> Sent: Sunday, June 15, 2008 1:34 AM
> database
> Hi Regina!
> Sorry took me so long to reply to this post, crazy week around here,
> but thank god there's always a weekend to look forward!
> This week I tried this method twice but finally had to stop it. First
> time I stopped the query after 4 hours thinking there was something
> wrong. Two nights later I tried again, left it running all night, next
> day, almost 10 hours later the query was running still. My table has
> 123,000+ rows, and just want to ask you if for such size is normal to
> take that long, if so I'll try again, if not, if you don't think it
> should take that long then you have any other suggestion?
> Thanks again!
>> I wonder if its just called Equals in the old version.
>> Try doing just ~=. If your geometries are exactly the same that will
>> probably be better anyway
>> DELETE FROM mystreets_table
>> WHERE street = 'N/A' AND
>> EXISTS (SELECT n.street FROM mystreets_table n WHERE n.street <> 'N/A'
>> AND n.street > '' AND n.the_geom ~= mystreets_table.the_geom)
>> Hope that helps.
>> Regina
>> SenTnel
>> Sent: Saturday, June 07, 2008 4:36 PM
>> database
>> Hello Regina! Thanks for your help, but when I try running it I got
>> this error message:
>> ERROR: function st_equals(geometry, geometry) does not exist
>> HINT: No function matches the given name and argument types. You may
>> need to add explicit type casts.
>> :confused:
>> Thanks!
>>> Here is a thought, but not sure how slow this will be
>>> EXISTS (SELECT n.street FROM mystreets_table n WHERE (n.street <> 'N/A'
>>> AND
>>> n.street > '') AND ST_Equals(n.the_geom, mystreets_table.the_geom))
>>> The st_equals might be better to replace with ~= if you want to
>>> match exact vertices. I presume ~= is actually more efficient
>>> Hope that helps,
>>> Regina
>>> SenTnel
>>> Sent: Saturday, June 07, 2008 2:25 AM
>>> Subject: Re: [postgis-users] Updated shapefile to update postgres
>>> database
>>> Hello! Im confused about this issue:
>>> I have a street (polyline) duplicated, one on top of the other,
>>> exact same features, same "the_geom", but one bears the street name
>>> (column:"street") "main street" and the other bears "N/A" as street
>>> name. Now my maps shows the street but the name that shows is "N/A",
>>> and I would like to delete the "N/A" polyline, how can i do
>>> basically
>>> this:
>>> delete from mystreets_table street = 'N/A' where 'N/A' = street
>>> 'main street'.the_geom (delete from mystreets table the street named
'N/A'
>>> where the_geom in 'N/A'
>>> equals the_geom in street "main street") another words, delete only
>>> the N/A streets that the_geom is same as "main street", I hope you
>>> understand,
>>> Thanks!
>>> SenTnel wrote:
>>>> Thanks Regina, Chris and all of you for your help. Im truly newby
>>>> but with such help Im ready to start the procedures, Ill keep you
>>>> posted of my progress or else if some issue comes along that may
>>>> require some light from you, Thanks again and I hope my
>>>> problem/solution may be of help to many others,
>>>> Thanks again!
>>>> SenTnel wrote:
>>>>> Hello!
>>>>> I would like some help updating a postgres database. This is the
>>>>> problem:
>>>>> We created the database using shp2pgsql to convert a shapefile
>>>>> that contains a city's street details (centerline), after we
>>>>> created the database we also created an aditional column to
>>>>> classify the street types
>>>>> (eg: street, avenues, highways, etc.), now we are working on the
>>>>> original shapefile, updating new roads, changes made to highways
>>>>> due to constructions modifications, etc., and we want to upload
>>>>> the "updated"
>>>>> shapefile, without afecting the actual database, another words, we
>>>>> would like to convert to postgres the updated shapefile with the
>>>>> new information (it cuold be the whole shapefile) but to keep the
>>>>> added clasiffication column intact. How can we do that?
>>>>> Thanks
>>> View this message in context:
>>> http://www.nabble.com/Updated-shapefile-to-update-postgres-database-
>>> t
>>> p
>>> 170535
>>> 62p17705777.html
>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> http://www.nabble.com/Updated-shapefile-to-update-postgres-database-t
>> p
>> 170535
>> 62p17712835.html
> http://www.nabble.com/Updated-shapefile-to-update-postgres-database-tp
> 170535
> 62p17846638.html
http://www.nabble.com/Updated-shapefile-to-update-postgres-database-tp170535
62p17847480.html
