[postgis-users] shp2pgsql: Handling numeric field containing scientific notation
Paul Ramsey pramsey at cleverelephant.ca
Wed Jun 18 02:31:54 PDT 2008
The numeric cast is a cute hack, but it won't work when shp2pgsql is
in -D dump mode, since dump expects you to give it the right forms
directly.
Have you filed this issue in the bug tracker?
P
On Tue, Jun 17, 2008 at 8:04 AM, hustvedt <hustvedt at gmail.com> wrote:
> Hello,
> There is what appears to be a slight issue with the .dbf part of a shapefile
> generated by ArcEditor 9.0 or 9.1 that has a value in an integer field of 10
> billion or more if that shapefile is then used with shp2pgsql. Attempting to
> load the resulting sql file results in a casting error. One possible
> solution is to cast the field to numeric in the sql output, before pgsql
> attempts to store it in a int8 field.
> How common is this issue?
> If a shapefile has an integer column with a value of 10 billion, some
> versions of ERSI ArcEditor will store that into the .dbf as "1.00e+010". As
> far as I can tell, that is an invalid string to store in a dBase III file,
> since the only characters allowed in a Numeric field are {+-.0123456789}.
> shp2pgsql doesn't do any coversions on what is stored in the .dbf file, so
> that gets put directly into the .sql file that is generated. It does set the
> types of the fields in the sql file, of course, so that affects the castings
> that pgsql is going to do. "1.00e+010" is a valid numeric type, and that can
> be casted to an int8, with any necessary rounding done. It is not a valid
> int8 value, even if it will fit into an int8 field. shp2pgsql deduces
> correctly that an int8 will be needed to store the resulting number, but I
> think that is only based on the field length from the header of the .dbf
> file.
> One solution is that for any field that has a type of an integer, to add an
> explicit cast to numeric in the sql file, then psql will be able to handle
> this case. This is a simple solution, since it is just adding a "::numeric"
> after any integer field value. Patching shp2pgsql and adding a
> 'printf("::numeric);' is the easiest way to do that I can see.
> Here is what the current code will tell psql to do, and the resulting error:
> # select '1.00e+010'::integer;
> ERROR:  invalid input syntax for integer: "1.00e+010"
> However, if that value is cast to ::numeric first, then it will work as an
> int8:
> # select '1.00e+010'::numeric;
>  numeric  -------------
> 10000000000
> (1 row)
> # select '1.00e+010'::numeric::int8;
>   int8    -------------
> 10000000000
> (1 row)
> The command line we use is "shp2pgsql -g the_geom -W UTF8 -s 4326 -c -N skip
> SAPEFILE TABLE > SQL"
> Running this sql code that shp2pgsql created generates the error, 'PGError:
> ERROR:  invalid input syntax for integer: "1.00e+010" ':
> CREATE TABLE "data_staging"."shp_121336819166268_20867" (gid serial PRIMARY
> KEY,
> "flag" int2,
> "v1" varchar(2),
> "v2" varchar(1),
> "v3" varchar(3),
> "v4" varchar(3),
> "v5" varchar(2),
> "v6" varchar(5),
> "v6a" varchar(16),  "v7" varchar(50),
> "v7a" int4,
> "v8" varchar(45),
> "v9" varchar(5),
> "v10" varchar(6),
> "v11" int8,
> "v12" varchar(32),
> "v13" varchar(2),
> "v17" varchar(50),
> "v18" varchar(50),
> "address" varchar(45),
> "city" varchar(32),
> "state" varchar(2),
> "zipcode" varchar(5),
> "zip_p4" varchar(4),
> "v25" varchar(9),
> "zip_p4_a" varchar(10),
> "v33" varchar(10),
> "v34" int2,
> "v38" int2,
> "v39" int2,
> "v40" int2,
> "v41" int2,
> "v42" int2,
> "v43" int2,
> "v44" int2,
> "v45" int2,
> "v46" int2,
> "v47" int2,
> "v52" int2,
> "v53" int2,
> "v54" int2,
> "v55" int2,
> "v56" int2,
> "v57" int2,
> "v58" int2,
> "v59" int2,
> "v60" int2,
> "v61" int2,
> "v62" int2,
> "v62f" int2,
> "v63" int2,
> "v63f" int2,
> "v64" int2,
> "v64f" int2,
> "v65" int4,
> "v65f" int2,
> "v66" int4,
> "v66f" int2,
> "v67" int4,
> "v67f" int2,
> "v68" int4,
> "v68f" int2,
> "v69" int4,
> "v69f" int2,
> "v70" int4,
> "v70f" int2,
> "v71" int4,
> "v71f" int2,
> "v72" int4,
> "v72f" int2,
> "v73" int4,
> "v73f" int2,
> "v74" int4,
> "v74f" int2,
> "v75" int4,
> "v75f" int2,
> "v76" int4,
> "v76f" int2,
> "v77" int4,
> "v77f" int2,
> "v78" int4,
> "v78f" int2,
> "v79" int4,
> "v79f" int2,
> "v80" int4,
> "v80f" int2,
> "v81" int4,
> "v81f" int2,
> "v82" int8,
> "v82f" int2,
> "v83" int2,
> "v84" int8,
> "v84f" int2,
> "v85" int4,
> "cp_pct" float8,
> "filter__" int2,
> "sizecat" float8,
> "joyce_st" float8,
> "longitude" numeric,
> "latitude" numeric,
> "georesult" varchar(11),
> "georstclp" varchar(2),
> "fid_1" numeric,
> "correction" varchar(50),
> "long_adj" numeric,
> "lati_adj" numeric);
> SELECT
> AddGeometryColumn('data_staging','shp_121336819166268_20867','the_geom','4326','POINT',2);
> INSERT INTO "data_staging"."shp_121336819166268_20867"
> ("flag","v1","v2","v3","v4","v5","v6","v6a","v7","v7a","v8","v9","v10","v11","v12","v13","v17","v18","address","city","state","zipcode","zip_p4","v25","zip_p4_a","v33","v34","v38","v39","v40","v41","v42","v43","v44","v45","v46","v47","v52","v53","v54","v55","v56","v57","v58","v59","v60","v61","v62","v62f","v63","v63f","v64","v64f","v65","v65f","v66","v66f","v67","v67f","v68","v68f","v69","v69f","v70","v70f","v71","v71f","v72","v72f","v73","v73f","v74","v74f","v75","v75f","v76","v76f","v77","v77f","v78","v78f","v79","v79f","v80","v80f","v81","v81f","v82","v82f","v83","v84","v84f","v85","cp_pct","filter__","sizecat","joyce_st","longitude","latitude","georesult","georstclp","fid_1","correction","long_adj","lati_adj",the_geom)
> VALUES ('0','IL','2','024','001','02','60100','1420240010260100','ALBION
> POLICE
> DEPT','88','ALBION','17047',NULL,'1933','EDWARDS','03',NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,'9999','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','3','0','3','0','3','999999','9','3','0','0','0','0','0','0','0','0','0','0','0','3','0','0','0','2','3','0','3','0','3','88888','8','88888','8','88888','8','88888','8','88888','8','1.00e+010','9','0','1.00e+010','9','0','0.00','1','1.00','0.00','-88.056282000','38.377029000','N','N','1856.000000',NULL,'-8.80562820000e+001','38.377029000','SRID=4326;01010000009F56D11F9A0356C061527C7C42304340');
> Anders Hustvedt
> http://mapbuzz.com
> postgis-users mailing list
