[postgis-users] export table from postgis to arcsde
Paragon Corporation lr at pcorp.us
Wed Jun 18 03:33:12 PDT 2008
I thought ogr2ogr can only read SDE.  I didn't realize it had write
capability to.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, June 18, 2008 5:37 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] export table from postgis to arcsde
If you have control of both the pgsql and the sde, you could use ogr2ogr and
a windows scheduler or cron job to fire it off and directly translate from
pgsql to sde.
P
On Wed, Jun 18, 2008 at 8:07 AM, Paragon Corporation <lr at pcorp.us> wrote:
> I use a PostgreSQL pgagent job to do nightly dumps of a PostgreSQL
> view put as an ESRI shape file.  I have people on the other end that
> have some automated routine for importing this shape file into a SQL
Server ArcSDE.
> I'm not sure how they do that, but I assume there most be some
> automated tool they use that loads shapefiles into ArcSDE.
> Hope that helps,
> Regina
> Benedetto Porfidia
> Sent: Tuesday, June 17, 2008 5:49 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] export table from postgis to arcsde
> I have a postgis database and i need to export a view from it to a sde
> db that is a source for arcims service. I should update a sde table
> with the postgis view. How can I do it?
> any hint is appreciated.
> Benedetto
> postgis-users mailing list
