[postgis-users] Re: Negative buffer chokes on Alaska
Sean Fulton seanasy at gmail.com
Mon Jun 23 19:46:38 PDT 2008
Yep. ST_IsValid returns true.
	Sean
On 2008-06-23 10:02:10 -0400, "Paul Ramsey" <pramsey at cleverelephant.ca> said:
> Have you run as ST_IsValid test on it?
> On Sun, Jun 22, 2008 at 7:47 PM, Sean Fulton <seanasy at gmail.com> wrote:
>> I have Census congressional district data loaded in a Postgis db. I want to
>> do a negative buffer on all of the districts. The data is in US National
>> Atlas (EPSG:2163).
>> Whenever I try to do a large (~10,000 m) buffer postgresql crashes. I
>> eventually figured out that Alaska was causing the problem. Reducing the
>> buffer gives unusual results for Alaska. A -500m buffer produces the image
>> attached (blue = buffer result, green = original data).
>> Postgis: POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
>> 2007" USE_STATS
>> Original data: http://dpaste.com/58232/plain/
>> Is it a problem with the data? With Postgis?
>> Thanks in advance,
>> Sean
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
