[postgis-users] ShapeFile Import
Bob Pawley
rjpawley at shaw.ca
Wed Jun 25 09:42:15 PDT 2008
No the shape file is "dv99_00.shp" - Public.Temp3 is the name of the schema
and table I want to create for the shape information. At least that's my
understanding.
Bob
----- Original Message -----
From: "Chris Hermansen" <chris.hermansen at timberline.ca>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Wednesday, June 25, 2008 9:26 AM
Subject: Re: [postgis-users] ShapeFile Import
> Is the name of your shape file Public.Temp3.shp? Try that.
> As for the database, you probably need to add a password to your role. If
> memory serves, you would use the SQL command ALTER ROLE, so check that out
> in the PostgreSQL documentation.
> Bob Pawley wrote:
>> I am attempting to use the shapefile conversion/upload found in the
>> documents.
>> shp2pgsql "dv99_00.shp" Public.Temp3 | psql -d Temp_
>> If I understand correctly there is the shape file, the table to be
>> generated then the table to drop.
>> However I get two problems.
>> 1 - I get message that the shape files can not be opened.
>> 2 - I'm asked for a password. When I enter the database password I get
>> message that the password was rejected - but in refernce to the name of
>> this computer - which has no password.
>> If anyone can help I would appreciate it.
>> Bob
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Regards,
> Chris Hermansen mailto:chris.hermansen at timberline.ca
> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
