[postgis-users] ST_Contains - WGS84
William Temperley
willtemperley at gmail.com
Fri Jun 27 01:49:22 PDT 2008
Hi all
Is there currently an accurate way to run queries like ST_Contains on
geodetic data?
My dataset is global and I may have to perform queries on a
continental scale, e.g. find all the points in Africa. I don't think
I can reproject to the UTM zone in question, given the queries will
span several zones. Is there a projection I can use temporarily to
perform queries like this?
I'm also slightly worried that the planar nature of the spatial
indexes could prematurely remove points from the result set - is this
the case?
Will
