[postgis-users] Collecting points for the overall bounding box
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Mon Jun 30 08:19:28 PDT 2008
Just to clarify, I didn't test out the query before I sent it.  If you
use the syntax that I gave, you will need to set the SRID on the
geometry returned from extent(), as follows:
select box2d(transform(setsrid(extent(geometry),26918),4326)) from
mytable
Where you would put your geometries original projection is in place of
26918.
HTH
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Burgholzer,Robert
Sent: Monday, June 30, 2008 10:08 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Collecting points for the overall bounding
box
Marc,
Would the following work: box2d(transform( extent(wkb_geometry), 4326) )
I think that you will achieve an efficiency from the following points:
1.      you should not need to collect, if all you want is the bounding
box, since extent() should give you that
2.      Even if you DO have to use collect, you will save lots of
computation time by doing the transform on the final aggregate (1
transform), rather than for every record (100,000 transforms).
804-698-4405
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Marc
Jacquin
Sent: Monday, June 30, 2008 9:23 AM
To: 'PostGIS Users Discussion'
Subject: [postgis-users] Collecting points for the overall bounding box
Hi all,
The request is quite simple, something like:
SELECT box2d(collect(transform(wkb_geometry,4326))) FROM mytable
Mytable contains about 100000 records of a point type geometry. A GIST
index is available for the table but it takes several minutes on a
respectable recent dual-core with 4 Gb of RAM.
Any idea would be helpful.
Thx.
Marc
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080630/4f7a02b2/attachment.html>
