[postgis-users] shp2pgsql not loading table in Postgis
Steven De Vriendt gisaalter at gmail.com
Mon Mar 3 13:19:40 PST 2008
Another addition to this (bit off topic, though): sometimes you have to run
a command twice in
order to get a command executed. It happens that when the initial
command is executed, Postgres/PostGIS throws an error. When running
the command for the second time, all is ok..
On Mon, Mar 3, 2008 at 10:09 PM, Steven De Vriendt <gisaalter at gmail.com>
wrote:
> In addition to that, using the latest release of Postgres I had to rename
> libiconv2.dll to libiconv-2.dll in order to use shp2pgsql in Windows
> Vista.
> Whitout renaming, shp2pgsql crashes on this dll
> Steven
> On Mon, Mar 3, 2008 at 8:21 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > Sometimes the pipe operation ain't great on Windows, try doing it in two
> > steps
> > shp2psql > file.sql
> > psql -f file.sql
> > On 2/28/08, Intengu Technologies <sindile.bidla at gmail.com> wrote:
> > > I am running Windows with Postgis 1.3.2 (installed using Appication
> > Stack
> > > Builder) on Postgresql 8.3 on running shp2pgsql.exe -s 4148
> > c:\province.shp
> > > province | psql -d spatialdb -U username and then entering password,
> > the
> > > table is not loaded.  What could I be doing wrong.
> > > Sindile Bidla
> > > _______________________________________________
> > >  postgis-users mailing list
> > >  postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080303/7d23a8cb/attachment.html>
