[postgis-users] Postgresql 8.3 on windows and geomunion
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Mar 5 03:04:47 PST 2008
On Wednesday 05 March 2008 03:56:14 Sanglant wrote:
> I've run into the same problem, plus a few others that didn't show in 8.2,
> using postgresql 8.3.0 along with PostGIS 1.3.2 on MS Windows. I not
> familiar enough to write a self-contained sql test case so I'll try and
> describe what I'm seeing and hope for the best.
> On the initial install everything seems to go well except plpythonu fails
> to install due to an inability to find the dll which, after the install, is
> present in the /lib directory.
> To familiarize myself with PostGIS I tried running through Boston GIS's
> tutorial at http://www.bostongis.com/?content_name=postgis_tut01#20 and hit
> an error when trying to run shp2pgsql. The executable looks for
> libiconv-2.dll which, while the correct file name for 8.2, in 8.3 the file
> is name libiconv2.dll. Creating a copy with the 8.2 naming style appears to
> fix the problem.
> Executing the sample statement "select area(geomunion(the_geom)) from towns
> where town = 'BOSTON';" gives an "ERROR: Operation on mixed SRID geometries
> SQL state: XX000". Running a quick "select distinct srid(the_geom) from
> towns;" shows that all rows are set to srid 26986.
> Brad
Hi Brad,
Thanks for the report. I've added this to the known issues/patches section of
the PostGIS wiki, so it's on the queue to be reviewed during the next
development cycle.
I really can't get into the Google Bug Tracker at all :(
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
