[postgis-users] PostGIS to GML?
Uwe Seher
uwe.seher at googlemail.com
Sun Mar 9 09:56:32 PDT 2008
Hi!
As i think, ST_AsGML (PostGIS 1.3) in a SQL-statement should do this. You
will find information in the manual.
CU Uwe Seher
On Sun, 09 Mar 2008 04:45:06 +0100, Jeshua Lacock <jeshua at 3DTOPO.com>
wrote:
> Hello,
> I was wondering if anyone knew of a PostGIS to GML solution? I can use
> pgsql2shp, and then use GDAL to convert to GML, however I would like to
> do it in one process.
> It seems like it would be easy enough to write something called
> "pgsql2gml" myself (parse a SQL dump with GML tags), but if something
> already exists, it would beat reinventing the proverbial wheel...
> Thanks,
> Jeshua Lacock
> Founder/Programmer
> 3DTOPO Incorporated
> <http://3DTOPO.com>
> Phone: 877.240.1364
> postgis-users mailing list
http://www.gispunkt.de
