[postgis-users] Turn a Polygon into Lines
Martin Davis mbdavis at refractions.net
Mon Mar 10 11:23:30 PDT 2008
It sounds like what you are looking for is a way to turn a set of
non-overlapping polygons and turn them into a polygonal coverage (or at
least produce the arcs in that coverage).
I don't think there's any easy way of doing this in PostGIS.  I'm not
sure that Regina's & Kevin's suggestions will produce the non-shared,
unique node-to-node arcs that are required.
The usual algorithm for doing this is:
- extract all line segments from each input polygon, labelled with the
polygon ID on the appropriate side
- merge duplicate segments, also merging the labels (on the appropriate
side).  To identify duplicate segments and merge them, segments will
need to be reoriented so that they are in a consistent direction (and
the labels flipped accordingly)
- "sew" the resulting set of line segments together to create linestring
edges from 3-node to 3-node  (e.g. eliminating "non-topologically
significant" 2-nodes
You might be able to create some SQL and/or stored proc code to do this
- it would be interesting to see how complicated and performant this
would be.
Lee Hachadoorian wrote:
> I'm looking through the PostGIS reference, and I can't seem to find a
> way to take a geometry of polygons and turn it into lines.  What I'm
> looking for is something like the ArcGIS Feature to Line geoprocessor,
> which will create a line shapefile where each feature is an arc
> representing the boundary between neighboring polygons with a field
> indicating the ids of the polygon on either side.
> Functions like ST_MakeLine require point geometries, and I don't see
> anything else that seems to be what I'm looking for.  Any ideas would
> be welcome.
> Thanks,
> Lee Hachadoorian
> PhD Student in Geography
> Program in Earth & Environmental Sciences
> CUNY Graduate Center
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
