[postgis-users] Turn a Polygon into Lines
Andre Schoonbee andresch at iway.na
Mon Mar 10 22:57:33 PDT 2008
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Monday, March 10, 2008 9:51 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Turn a Polygon into Lines
I concur, it sounds like you're after topology support in PostGIS.
Regina's function will simply provide you with the raw lines that make
up a polygon (the first half of Martin's first bullet item).  Topology
in PostGIS is very much in a pre-alpha stage.  There is an underlying
topology datamodel, but that's about it.  The stored procedures Martin
was referring to has yet to be developed.
(see this thread
http://postgis.refractions.net/pipermail/postgis-users/2007-October/017530.h
tml)
Cheers,
Kevin
Martin Davis wrote:
> It sounds like what you are looking for is a way to turn a set of
> non-overlapping polygons and turn them into a polygonal coverage (or
> at least produce the arcs in that coverage).
> I don't think there's any easy way of doing this in PostGIS.  I'm not
> sure that Regina's & Kevin's suggestions will produce the non-shared,
> unique node-to-node arcs that are required.
> The usual algorithm for doing this is:
> - extract all line segments from each input polygon, labelled with the
> polygon ID on the appropriate side
> - merge duplicate segments, also merging the labels (on the
> appropriate side).  To identify duplicate segments and merge them,
> segments will need to be reoriented so that they are in a consistent
> direction (and the labels flipped accordingly)
> - "sew" the resulting set of line segments together to create
> linestring edges from 3-node to 3-node  (e.g. eliminating
> "non-topologically significant" 2-nodes
> You might be able to create some SQL and/or stored proc code to do
> this - it would be interesting to see how complicated and performant
> this would be.
> Lee Hachadoorian wrote:
>> I'm looking through the PostGIS reference, and I can't seem to find a
>> way to take a geometry of polygons and turn it into lines.  What I'm
>> looking for is something like the ArcGIS Feature to Line
>> geoprocessor, which will create a line shapefile where each feature
>> is an arc representing the boundary between neighboring polygons with
>> a field indicating the ids of the polygon on either side.
>> Functions like ST_MakeLine require point geometries, and I don't see
>> anything else that seems to be what I'm looking for.  Any ideas would
>> be welcome.
>> Thanks,
>> Lee Hachadoorian
>> PhD Student in Geography
>> Program in Earth & Environmental Sciences
>> CUNY Graduate Center
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
__________ Information from ESET Smart Security, version of virus signature
database 2935 (20080310) __________
The message was checked by ESET Smart Security.
http://www.eset.com
