[postgis-users] line_interpolate_point complains on 2nd Arg
Sufficool, Stanley
ssufficool at rov.sbcounty.gov
Wed Mar 12 08:20:21 PDT 2008
I have verified the CASE statements for the line_interpolate_point
(returns .10101010101). My problem evidently was with line_substring
where I was specifying the distance along the line instead of a float
percentage. Problem solved.
It would be great if PostGIS had a line_interpolate_point_offset(line,
percent, offset, angle) for doing this and offsetting the point to the
left (angle = -90)/right (angle = 90) of the line segment to which it
was matched.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Kevin Neufeld
> Sent: Tuesday, March 11, 2008 7:16 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] line_interpolate_point complains
> on 2nd Arg
> Are you sure you've verified the range is [0,1]? Try your query with
> just selecting the case statements:
> SELECT
> CASE WHEN ... END AS param1,
> CASE WHEN ... END AS param2,
> FROM countrystreets ...
> If so, can you isolate the geometry that is causing the
> error? If it's
> not too large, post the WKT or hexstring representation here.
> -- Kevin
> Sufficool, Stanley wrote:
> > I have been attempting to find a SQL only geocode query for our
> > specific dataset and arrived at the following.
> > complains that the 2nd param is out of range [0,1]. I verified that
> > the value returned is 0.101010101010101 (float8). I have
> replaced the
> > "CASE" with this value and it still complains.
> > The query interpolates the point, grabs the line segment
> and offsets
> > the point to the left/right of the street segment by 50 units.
> > PostgreSQL 8.0.15, Gentoo Linux x86, PostGIS 1.3.1
> > SELECT
> > translate(
> > line_interpolate_point (
> > the_geom,
> > CASE WHEN ( (320 % 2) = (l_add_from % 2) )
> > THEN ( (320 - l_add_from) / (l_add_to -
> > l_add_from) )
> > ELSE ( (320 - r_add_from) / (r_add_to -
> > r_add_from) )
> > END::float
> > CASE WHEN (320 % 2) = (l_add_from % 2) THEN
> > (x(line_substring(the_geom,
> > length(the_geom) * ( (320 - l_add_from)
> > / (l_add_to - l_add_from) ),
> > / (l_add_to - l_add_from) ) + 50)))
> > ELSE
> > -(x(line_substring(the_geom,
> > length(the_geom) * ( (320 - r_add_from)
> > / (r_add_to - r_add_from) ),
> > / (r_add_to - r_add_from) ) + 50)))
> > END,
> > -(y(line_substring(the_geom,
> > ELSE
> > END
> > ) as address_point,
> > CASE WHEN (320 % 2) = (l_add_from % 2) THEN 'LEFT' else
> 'RIGHT' END
> > as street_side
> > FROM countystreets s
> > WHERE CASE WHEN (320 % 2) = (l_add_from % 2) THEN (l_add_to -
> > l_add_from) ELSE (r_add_to - r_add_from) END > 0
> > AND s.pre_dir = 'E'
> > AND replace(s.street_name,' ','') = 'PHILLIPS'
> > AND s.street_type = 'ST'
> > AND s.suf_dir = ''
> > AND s.l_zipcode = substr('91761-4230',1, 5)
> > AND (
> > 320 BETWEEN l_add_from and l_add_to
> > OR 320 BETWEEN r_add_from and r_add_to
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
