[postgis-users] Postgis Area size problem
Paulius J
paulius at digitalwork.lt
Wed Mar 12 09:52:35 PDT 2008
Hello, GL,
Thanks, for your post. The first part of the problem is easy and at last I
got the query working :) While I have some questions about the second:
'- You should use UTM zone 35N, which is the one for Lithuania'. Here as I
understand you are talking about SRID`s? If yes, so is it a difference which
SRID I am using (I use the database only to save points or group of points
from GPS and Google Maps? In database I only want to save the lat and lon
from GPS device or Google Maps on the global scope, so which SRID should I
use, or there is no difference in my situation? The boundaries of Lithuania
is only an example because I live here.
P.S. sorry for such a question but I am new in this.
Paulius J
Guido Lemoine wrote:
> PJ,
> I guess your dealing with Lithuania data. Your problem is twofold:
> - You have lat and lon in the wrong order
> Hence, do the following:
> select st_area(st_transform(geometryFromText('POLYGON((21.06079 56.05364
> ,22.12646 56.43213 ,24.55444 56.27386 ,24.88403 56.41998
> ,25.10376 56.17002 ,26.63086 55.6528 ,26.25732 54.965 ,25.75195 54.78168
> ,25.62012 54.31652 ,25.74097 54.14957 ,25.53223 54.18173 ,25.47729
> 54.28447
> ,24.37866 53.90434 ,23.47778 53.96255 ,23.20313 54.25881 ,22.77466
> 54.35496
> ,22.82959 54.78802 ,22.65381 54.95239 ,21.32446 55.26034 ,21.0498 56.0475
> ,21.06079 56.05364 ))', 4326), 32635));
> --> 64039242950.5568 (sqm)
> GL
> Paulius J wrote:
>> Thank you for your quick reply Nicolas,
>> Now I get the results which are more likely to be the truth, but they
>> differ
>> from reality quiet a lot.
>> Maybe it can be a problem that I got these coordinates from Google Maps?
>> If
>> I am correct, the polygon which I posted as example should be about 64
>> 000
>> square kilometers.
>> Paulius J
>> Nicolas Ribot wrote:
>>> On 11/03/2008, Paulius J <paulius at digitalwork.lt> wrote:
>>>> Hello,
>>>> I have such a problem. Here is my polygon and it looks that everthing
>>>> is
>>>> allright:
>>>> POLYGON((56.05364 21.06079,56.43213 22.12646,56.27386
>>>> 24.55444,56.41998
>>>> 24.88403,56.17002 25.10376,55.6528 26.63086,54.965 26.25732,54.78168
>>>> 25.75195,54.31652 25.62012,54.14957 25.74097,54.18173
>>>> 25.53223,54.28447
>>>> 25.47729,53.90434 24.37866,53.96255 23.47778,54.25881
>>>> 23.20313,54.35496
>>>> 22.77466,54.78802 22.82959,54.95239 22.65381,55.26034 21.32446,56.0475
>>>> 21.0498,56.05364 21.06079))
>>>> But when i want to find the area of it using Area i get the result:
>>>> 9.04832470074997
>>>> I do not know how to get the area size in square meters or something
>>>> similar
>>>> to this? Maybe i should use some other function, but according the
>>>> postgis
>>>> manual I use Area or ST_Area and have such problem...
>>>> P.S. i am using SRID = 4326 for the Geometry column.
>>> ST_area computes the area in geometry's units. Here square degrees.
>>> Repreject your data in a metric reference system (like UTM for
>>> instance) with st_transform(), then compute the area.
>>> Something like:
>>> select st_area(st_transform(geometryFromText('POLYGON((56.05364
>>> 21.06079,56.43213 22.12646,56.27386 24.55444,56.41998
>>> 25.75195,54.31652 25.62012,54.14957 25.74097,54.18173 25.53223,54.28447
>>> 25.47729,53.90434 24.37866,53.96255 23.47778,54.25881 23.20313,54.35496
>>> 21.0498,56.05364 21.06079))', 4326), 32640));
>>> Nico
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Guido Lemoine
> Joint Research Centre, European Commission
> Institute for the Protection and Security of the Citizen (IPSC)
> Support to External Security
> Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
> Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
> WWW: http://ses.jrc.it
> Disclaimer:
> Views expressed are those of the individual and do not represent
> the views of the European Commission
View this message in context: http://www.nabble.com/Postgis-Area-size-problem-tp15988337p16008014.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
