[postgis-users] Does geometry field type have a size limit?
Paul Ramsey
pramsey at cleverelephant.ca
Wed Mar 12 10:13:46 PDT 2008
There is no limit to the geometry field size (well, no practical limit
http://www.postgresql.org/about/, 1Gb) .
Send me your shape file to confirm if your problem is repeatable.
P.
On 3/12/08, davidj2k <davidj2k at yahoo.com> wrote:
> I am trying to convert several of my .shp files to the PostGIS database and
> when it inserts some of the larger polygons it fails to insert the geometry
> field value.
> I tried it using the shp2pgsql and I tried it using my own code in C# and I
> have even tried executing the SQL in the pgAdmin III Query function and all
> three have the exact same results the record gets inserted but the geometry
> field is null and it only happens on those records that have a lot of points
> that make up the polygon, I created several test to try and determine how
> many points were too much for it and I hit upon 1365 seemed to be the amount
> that was too many.
> Does anybody know if there is a limitation to the geometry field and if
> there is how can I increase it?
> Thank You
> View this message in context: http://www.nabble.com/Does-geometry-field-type-have-a-size-limit--tp16006438p16006438.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
