[postgis-users] Topological Exceptions
Paul Ramsey
pramsey at cleverelephant.ca
Wed Mar 12 10:17:31 PDT 2008
Hard. An "ERROR()" geometry type is almost called for, so that you can
run the whole set and actual inspect post-facto which ones failed.
The most annoying part of the current behavior for me is the
difficulty tracking down the problematic pair of geometries. I think
you're right, the current fail-and-stop behavior causes more problems
than it solves.
On 3/11/08, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> I've been doing a lot of work using ST_Intersection, ST_Difference, ST_Union
> etc to cut out slices of geometries I don't want and slicing up geometries
> into smaller pieces, reunioning etc.
> I've been running into a lot of Topological Exceptions of the form directed
> Edge this and non-noded that. For the most part I've been able to overcome
> these by slicing things smaller or skipping over problem regions (e.g. areas
> where the difference is a line or point or something of that sort).
> I think a lot of people have run into the same issues and have gotten
> frustrated and there doesn't seem to be a simple solution suggested to
> overcome these.
> Is there any way we can change (add overloaded functions or some setting
> parameter) - that take additional parameters to simply ignore these errors
> that says return empty collection or NULL when a GEOS error is thrown. That
> way I can simply ignore these and throw them out of my equation and move on.
> Just a thought. I'm sure my suggestion is rather simple-minded and I'm sure
> I'm missing some reason of why this is not feasible. An explanation of why
> my suggestion is stupid at anyrate would be nice.
> Thanks,
> Regina
> ________________________________
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
> Help make the earth a greener place. If at all possible resist printing
> this email and join us in saving paper.
> postgis-users mailing list
