[postgis-users] Topological Exceptions
Martin Davis
mbdavis at refractions.net
Wed Mar 12 16:07:09 PDT 2008
A reasonable concern.
To which some might be tempted to reply RTFM. (I think this is the
solution offered by some proprietary vendors...)
Would having parallel sets of functions, (Paranoid/Laissez-faire) be an
option? Unpleasant to widen the API, however.
Paul Ramsey wrote:
> Before getting too enthused about this, the net effect will be to
> convert a whole bunch of questions about "why is my query failing" to
> "why is my query returning incomplete answers"...
> We can still spit out NOTICEs, but will people put 2 + 2 together and
> recognize that their return sets are partials because of the topology
> failures?
> P
> On 3/12/08, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> On 3/12/08, Martin Davis <mbdavis at refractions.net> wrote:
>> > Orginally the idea was that it was nice to report the actual nature of
>> > the exception, since it contains an indication of where the error
>> > occurred. It would be nice to be able to continue to have access to
>> > this information. One way to do this would be to have a parallel set of
>> > functions which would abort as they do now. Or is there some other way
>> > to report this info - to a log somewhere perhaps?
>> I prefer using something like NULL to trying to create a new geometry
>> type to encompass the error... particularly if the error conditions
>> aren't that interesting to people. We can get into the log easily
>> enough by using a WARNING log level, the only question then is how to
>> identify which geometries caused the failure. One way might be to
>> hash the geometries, so that if people want to find their bad
>> geometries from the log they can just select for the hash value.
>> This means that the return values of
>> ST_Contains(geom,geom) => true, false or null
>> and
>> ST_Intersection(geom,geom) => geometry or null
>> I just checked, and null seems to be interpreted as false in a WHERE
>> clause, so adding this behavior probably wouldn't wreck too many
>> joins.
>> Paul
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
