[postgis-users] st_union says geometries have different srids
Mike Leahy mgleahy at alumni.uwaterloo.ca
Sun Mar 16 21:14:31 PDT 2008
Hello list,
I seem to be having trouble with st_union as an aggregate function.
Sorry if this is a known issue, but a quick search didn't turn anything
up similar.  Below is an example where I have two polygons next to each
other
test=# create table test (gid serial primary key);
test=# select
addgeometrycolumn('public','test','test_geom',4326,'MULTIPOLYGON',2);
test=# insert into test (test_geom) values ('srid=4326;MULTIPOLYGON(((1
1,1 2,2 2,2 1,1 1)))');
test=# insert into test (test_geom) values ('srid=4326;MULTIPOLYGON(((2
1,3 1,3 2,2 2,2 1)))');
The following will fail no matter what shapes/srid I'm using:
test=# select st_union(test_geom) from test;
ERROR:  Operation on mixed SRID geometries
But this works fine:
test=# select st_memunion(test_geom) from test;
    st_memunion
  0103000020E610000001...
Is there something in particular that I'm doing wrong?  This only seems
to be an issue with st_union as an aggregate, if I use
st_union(geometry,geometry), the result looks fine.  This is on a
Fedora-7 (x86_64) machine with PostgreSQL 8.3, PostGIS 1.3.2,
Proj-4.5.0, GEOS-3.0.0 - I have a similar setup on another machine
running F8-x86_64 (except for Proj-4.6.0), and the failure is worse (the
postgresql server segfaults with 'signal 11').  Would this be a bug, or
have I committed some kind of user error?  Is there anything I should
try to figure out where the source of my problem is?
Thanks in advance for any suggestions.
Mike
