[postgis-users] AsGML and AsKML not working in 1.3.2?
Paul Ramsey pramsey at cleverelephant.ca
Mon Mar 17 12:27:34 PDT 2008
Run lwpostgis_upgrade.sql on your old database, that should refresh
the function signatures to match the underlying .so.
P
On 3/17/08, David Jordan <davidj2k at yahoo.com> wrote:
> I think I might know what the problem is, I am using a database that was
> created in an older version of PostGIS and I restored from a file, is there
> a simple way to update the functions in this database?  I can see the
> correct function in another database that was created in this version.
> Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> select postgis_full_version().
> I am seeing it work just fine on my installation...
> pramsey=# select st_asgml(test_geom) from test;
> On 3/17/08, David Jordan wrote:
> > If I try that I get
> > ERROR: 42883: function st_asgml(geometry) does not exist
> > Paul Ramsey wrote:
> > Try ST_AsGML and ST_AsKML
> > P
> > On 3/17/08, davidj2k wrote:
> > > I am trying to use the AsGML and AsKML functions in PostGIS 1.3.2 I get
> > this
> > > error when trying to use AsGML
> > > "ERROR: XX000: Only GML 2 and GML 3 are supported"
> > > The documentations says it is defined like this
> > > AsGML([version], geometry, [precision])
> > > But in the functions I see
> > > AsGML(geometry, int, int)
> > > I have tried calling it with and without a version number all seem to do
> > the
> > > same thing.
> > > Then I want to also call AsKML but that function does not appear to
> exist.
> > > I get this error
> > > "ERROR: 42883: function askml(geometry) does not exist"
> > > and I do not see it in the list of functions
> > > View this message in context:
> http://www.nabble.com/AsGML-and-AsKML-not-working-in-1.3.2--tp16098350p16098350.html
> > > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it
> > now.
> Never miss a thing. Make Yahoo your homepage.
