[postgis-users] Re: [Fwd: Error in PostGIS spatial_ref_sys table?]
Kevin Neufeld
kneufeld at refractions.net
Wed Mar 19 12:33:50 PDT 2008
Hi Martin,
I've forwarded your observation to the PostGIS list, where someone will
verify and post the bug in our PostGIS bug tracker.
Thanx,
Kevin
Jody Garnett wrote:
> Subject:
> From:
> Martin Desruisseaux <martin.desruisseaux at geomatys.fr>
> Date:
> Wed, 19 Mar 2008 20:00:46 +0100
> To:
> pramsey at refractions.net
> To:
> CC:
> jgarnett at refractions.net, Mickael.Treguer at ifremer.fr, Vincent
> Heurteaux <vincent.heurteaux at geomatys.fr>
> Hello Paul
> The spatial_ref_sys table in PostGIS defines EPSG:27572 ("NTF (Paris)
> / Lambert zone II") with the following element in the "srtext" column:
> PRIMEM["Paris", 2.33722917]
> it should be
> PRIMEM["Paris", 2.5969213]
> because the angle is supposed to be express in gradiants, not in
> degrees (the former is the correct longitude but in degrees. The later
> is the same longitude in gradiants).
> Quoting the OGC specification: "If the PRIMEM clause occurs inside a
> GEOGCS, then the longitude units will match those of the geographic
> coordinate system".
> http://geoapi.sourceforge.net/snapshot/javadoc/org/opengis/referencing/doc-files/WKT.html#PRIMEM
> It doesn't have any impact on the transformations performed by PostGIS
> since it relies on Proj4 and the definition in the "proj4text" is
> correct. But it impact the transformations performed by GeoTools when
> the later try to read the definition from the "srtext" column in a
> PostGIS database.
> The same probably applies to other CRS around EPSG:27572 (there is
> Lambert Zone I, Lambert Zone III, etc. I didn't checked them).
> Not a blocker issue for us - I have implemented a workaround. Just for
> letting you know.
> Regards,
> Martin
