[postgis-users] ST_Union and 8.3?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Mar 20 08:57:47 PDT 2008
On Thursday 20 March 2008 13:37:03 Obe, Regina wrote:
> Mark,
> Can you think of anything wrong with using ST_MemUnion as a temporary
> fix aside from the fact that I guess for larger unioning jobs it is
> probably less efficient?
I can't say that I've had much to do with that section of code - I think it
was probably strk that came up with the idea and implementation.
> Has anyone tried the new 8.3.1 to see if it changes the below issue.  I
> don't see anything in the list of changes
> http://www.postgresql.org/docs/8.3/static/release-8-3-1.html that would
> suggest it would, except possibly for
> "Fix memory leaks in certain usages of set-returning functions"
> I'm planning to try it out in the next day or so.
The discussion on -hackers was that objects created within each SRF were
living longer than intended. Now in the case of a buggy SRF this could cause
excess memory usage during execution that would only be freed at the end of
the SRF. However I have a feeling that most of the memory in PostGIS is being
held by GEOS so this may/or may not make a difference. But please feel free
to experiment :D
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
