[postgis-users] Do I need to copy postGIS objects to my new schema?
George Silva
georger.silva at gmail.com
Tue Mar 25 09:23:45 PDT 2008
when i create a postgis database i use a clean template_postgis database
(create at time of instalation) as template. Is this a ok / correct
practice?
Att.
George
Nicolas Ribot escreveu:
>> I'm planning to use database schemas to organize my spatial tables. For
>> example, all spatial tables of GIS objects belong to Bali island is to be
>> kept in a schema named "bali", etcetera.
>> Problem is, when I created a new schema named bali, it did not inherit all
>> the postGIS objects of the public schema.
>> As you can see on the attached screenshot (I'm using pgAdmin III), the
>> public schema contains all the Aggregates, Domains, Functions, etcetera,
>> which are all part of postGIS functionality. Examples are geomunion function
>> and earth domain, which exist in the public schema but do not exist on bali
>> schema.
>> Can I use bali schema to store postGIS tables then? Or should I copy all the
>> postGIS Aggregates, Domains, Functions, etc, to the bali schema in order to
>> make it work? And if that's the case, anyone know the easiest way to do so?
> Postgis functions should stay in the public schema. No need to copy them.
> You will be able to use them on the bali.* tables by either fully
> qualifying the tables' name in your queries or by adding your newly
> created schema to the search path (no need to qualify tables names
> with the schema in this case)
> Nicolas
> postgis-users mailing list
