[postgis-users] Spatial Analysis/Union of shapefiles
Obe, Regina
robe.dnd at cityofboston.gov
Wed Mar 26 06:00:14 PDT 2008
Not quite clear what you are trying to do
1) Do you have table a with n rows and table b with m rows (each having
the same fields) and you want table c with (m + n) rows.
This is a regular old SQL union and not a spatial union
So would be done with
INSERT INTO c(field1,field2, .., the_geom)
SELECT a.field1, a.field2, ... a.the_geom
FROM a
UNION ALL
SELECT b.field1, b.field2, ... b.the_geom
FROM b;
or are you trying to do a spatial union or intersection and in what case
what records are you trying to group together into a geometry or join by
There are so many permutations of spatial unions and spatial
intersections - that its hard to give an answer without having more
details about what you are trying to accomplish.
e.g a spatial intersection result may looks something like this
2)
INSERT INTO c(field1,field2, field3,.., the_geom)
SELECT a.field1, a.field2, b.field1 as field3 ..
ST_Intersection(a.the_geom, b.the_geom) as the_geom
FROM a INNER JOIN b on (a.zip = b.zip (or whatever field) and
ST_Intersects(a.the_geom, b.the_geom)
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of K.
Pandey
Sent: Tuesday, March 25, 2008 11:51 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Spatial Analysis/Union of shapefiles
I want to perform union of two shape files using postgresql.
I converted the shape files to postgres tables using shp2pgsql utility.
How to perform the union/intersection of these two tables.
Once the union/intersection is completed, I can convert the union file
back to shapefile using pgsql2shp utility.
Kamal Pandey
Dehradun
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080326/eeef6c3e/attachment.html>
