[postgis-users] st_makeline
Bob Pawley
rjpawley at shaw.ca
Sun May 4 17:29:37 PDT 2008
Thanks for your answer.
Is geometry and geometry set explained anywhere??
Bob
----- Original Message -----
To: PostGIS Users Discussion
Sent: Sunday, May 04, 2008 4:37 PM
Subject: Re: [postgis-users] st_makeline
Hi Bob,
I'm new to postgis as well (and am and loving it).
You do have syntax errors in your sql. Note the definitions of the functions that you are using from the postgis manual:
ST_MakePoint(<x>, <y>, [<z>], [<m>])
ST_MakeLine(geometry set)
ST_MakeLine(geometry, geometry)
So your point sql is valid as it accepts integers, though your line sql is not because you are not using a geometry type.
Try the following: st_makeLine(st_makePoint(0, 2), st_makePoint(0, 1))
HTH
Drew
On Mon, May 5, 2008 at 8:15 AM, Bob Pawley <rjpawley at shaw.ca> wrote:
Hi
I am trying to learn the basics of Postgis by populating a table with various geometries.
When I run this -
Insert into graphics.process (the_geom) values (st_makepoint(0 2));
it results in a point which I can see on the viewer.
However, when I run the following, or any variation of coordinate syntax to obtain a line, I get a syntax error.
Insert into graphics.process (the_geom) values (st_makeline (0 2), (0 1));
Or
Insert into graphics.process (the_geom) values (st_makeline (0 2, 0 1));
Or
Insert into graphics.process (the_geom) values (st_makeline (0 2 0 1));
Or
Insert into graphics.process (the_geom) values (st_makeline (0, 2, 0, 1));
Or
Insert into graphics.process (the_geom) values (st_makeline (0, 2), (0, 1));
Any thoughts would be appreciated.
Bob
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080504/7605d197/attachment.html>
