[postgis-users] question on returning area size using st_area.
Stephen Lee stephenljk at gmail.com
Tue May 6 00:35:02 PDT 2008
Thanks Robert,
I have run a query on spatial_ref_sys to check all projection related to
Malaysia and have found quite a few, by trying a few projection listed there
I have some result that is more likely to be true:
SELECT st_area(transform(the_geom, 3385)) / 10000 as hectares
FROM mal_state
WHERE name = 'KELANTAN'
thou i still have no way of verifying them, will try to verify it somehow.
thanks again for your fast and helpful response.
i do have another question, sorry if this is a newbie question, why do we
need to reproject it again if its in WGS84? i thought of putting all types
of free maps into one central database and open it to anyone who want to use
them, if this is the case, lets say someone contribute a map of Thailand,
how do i perform a spatial query if map in different geographic location has
to be manually handled? take for example, if a query involve both map in
Thailand and Malaysia, what kind of re-projection should i used? And how
come the sample data in PostGIS tutorial do not require a re-projection?
Start reading the PostGIS manual, really appreciate if someone can help
answer these questions or point me the right way. Thanks in advance.
Best regards,
Stephen
On Tue, May 6, 2008 at 3:02 AM, Burgholzer,Robert <
rwburgholzer at deq.virginia.gov> wrote:
>  Stephen,
> This is a classic, and I think it must be in some FAQ some where.  The
> only way I have done it is to re-project using the transform function to
> something whose units are in meters, since the 4326 SRID has distance units
> in meters.  Thus, something like the following:
> SELECT st_area(transform(the_geom, 26918)) / 10000 as hectares
> FROM mal_state
> Now, in this example, I have chosen SRID 26918, which off the top of my
> head is like NAD 1983, UTM Zone 17.  This is a fairly appropriate projection
> for my area (eastern US), however, I don't know enough about projections to
> say without reservation that you could use any old projection without
> concerning yourself with whether or not the projection you use is valid in
> the area that you are operating on in DD.
> If anyone else has better, more comprehensive insight on this, I for one
> would like to hear about it,
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Stephen Lee
> *Sent:* Monday, May 05, 2008 2:27 PM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] question on returning area size using st_area.
> hi there,
> i've just started using postgis, i have loaded a sample map of malaysia
> using the following command:
> F:\PROGRA~1\PostgreSQL\8.3\bin>shp2pgsql -c -s 4326
> G:\Maps\Malaysia\Detailsmaps\state_region public.mal_state > state.sql
> Shapefile type: Polygon
> Postgis type: MULTIPOLYGON[2]
> the projection file in the prj is as follow so I assume the SRID is 4326 :
> GEOGCS["Lat Long
> WGS84",DATUM["D_WGS84",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]
> the map is successfully loaded and can be viewed using uDig. The problem
> occurs when I tried to use the st_area command as state in the PostGIS
> (1.3.3) manual (4.6.2.2). the sql statement i issue is:
> SELECT
>   ST_Area(the_geom)/10000 AS hectares
> FROM mal_state
> WHERE name = 'KELANTAN';
> hectares
> 0.000122167591783352
> (1 row)
> is the return result measure in the unit of the WGS84 projection? if so
> how can i change it to the correct measurement? i have attached my map file
> in this email, can someone please shine some light? thanks in advance.
> best regards,
> Stephen
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080506/6b3781e7/attachment.html>
