[postgis-users] question on returning area size using st_area.
Burgholzer,Robert
rwburgholzer at deq.virginia.gov
Tue May 6 06:51:29 PDT 2008
Stephen,
I am shooting in the dark a little here, so, take what I say with a
grain of salt. Hopefully, someone will see my mangled attempt to
understand this, and chime in with something sensible.
My guess is that, even though the spheroid is WGS84, the units are set
in the SR_text, as follows (for SRID 4326 from my PostGIS db):
SRTEXT = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 8
4",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0
],AUTHOR
ITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT[
"degree"
,0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]]
Specifically, the parameter:
UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]]
Tells me that it wants the units to be in degrees? So then, what is the
0.0174xx number there? Once again, I can only speculate, but I am
assuming that perhaps this is a conversion to meters or some other
standard unit at some point on the map (perhaps at the prime meridian).
So, the real question may be, "can PostGIS be told to measure distance
in a specified unit other than by using a transform?".
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Stephen Lee
Sent: Tuesday, May 06, 2008 3:35 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] question on returning area size using
st_area.
Thanks Robert,
I have run a query on spatial_ref_sys to check all projection related to
Malaysia and have found quite a few, by trying a few projection listed
there I have some result that is more likely to be true:
SELECT st_area(transform(the_geom, 3385)) / 10000 as hectares
FROM mal_state
WHERE name = 'KELANTAN'
thou i still have no way of verifying them, will try to verify it
somehow. thanks again for your fast and helpful response.
i do have another question, sorry if this is a newbie question, why do
we need to reproject it again if its in WGS84? i thought of putting all
types of free maps into one central database and open it to anyone who
want to use them, if this is the case, lets say someone contribute a map
of Thailand, how do i perform a spatial query if map in different
geographic location has to be manually handled? take for example, if a
query involve both map in Thailand and Malaysia, what kind of
re-projection should i used? And how come the sample data in PostGIS
tutorial do not require a re-projection?
Start reading the PostGIS manual, really appreciate if someone can help
answer these questions or point me the right way. Thanks in advance.
Best regards,
Stephen
On Tue, May 6, 2008 at 3:02 AM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
Stephen,
This is a classic, and I think it must be in some FAQ some where. The
only way I have done it is to re-project using the transform function to
something whose units are in meters, since the 4326 SRID has distance
units in meters. Thus, something like the following:
SELECT st_area(transform(the_geom, 26918)) / 10000 as hectares
FROM mal_state
Now, in this example, I have chosen SRID 26918, which off the top of my
head is like NAD 1983, UTM Zone 17. This is a fairly appropriate
projection for my area (eastern US), however, I don't know enough about
projections to say without reservation that you could use any old
projection without concerning yourself with whether or not the
projection you use is valid in the area that you are operating on in DD.
If anyone else has better, more comprehensive insight on this, I for one
would like to hear about it,
804-698-4405
Stephen Lee
Sent: Monday, May 05, 2008 2:27 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] question on returning area size using st_area.
hi there,
i've just started using postgis, i have loaded a sample map of malaysia
using the following command:
F:\PROGRA~1\PostgreSQL\8.3\bin>shp2pgsql -c -s 4326
G:\Maps\Malaysia\Detailsmaps\state_region public.mal_state > state.sql
Shapefile type: Polygon
Postgis type: MULTIPOLYGON[2]
the projection file in the prj is as follow so I assume the SRID is 4326
GEOGCS["Lat Long
WGS84",DATUM["D_WGS84",SPHEROID["World_Geodetic_System_of_1984",6378137,
298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943
295]]
the map is successfully loaded and can be viewed using uDig. The problem
occurs when I tried to use the st_area command as state in the PostGIS
(1.3.3) manual (4.6.2.2). the sql statement i issue is:
SELECT
ST_Area(the_geom)/10000 AS hectares
FROM mal_state
WHERE name = 'KELANTAN';
hectares
0.000122167591783352
(1 row)
is the return result measure in the unit of the WGS84 projection? if so
how can i change it to the correct measurement? i have attached my map
file in this email, can someone please shine some light? thanks in
advance.
best regards,
Stephen
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080506/2462a3fa/attachment.html>
