[postgis-users] Points with in multiple Polygons
chris brisendine
ki4gyw at gmail.com
Tue May 6 12:19:06 PDT 2008
It Works!!! Thanks!! I might one day want to remove the "the_geom" is
that hard to do.
Thanks
On Tue, May 6, 2008 at 1:43 PM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
> You probably need the name of your database in the command line call
> with the "-d" switch.
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> chris brisendine
> Sent: Tuesday, May 06, 2008 1:25 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Points with in multiple Polygons
> I get a relation "nqaatt" does not exist. I changed the sql to show
> storm cells in the tornadowarning, it works fine in the pgAdmin III
> tool area here is the sql statement
> SELECT DISTINCT ON (ncities.name)
> ncities.name, ncities.the_geom
> FROM ncities INNER JOIN torpoly ON ST_Within(ncities.the_geom,
> torpoly.the_geom)
> ORDER BY ncities.name
> the command I am using is psql -f run.psql
> On Tue, May 6, 2008 at 12:12 PM, Burgholzer,Robert
> > You want to run that command with the "-f" switch, the "-c" switch is
> > for a single command, not a script file.
> > HTH
> > 804-698-4405
> > chris brisendine
> > Sent: Tuesday, May 06, 2008 11:35 AM
> > Great Idea on the tornado intersect it does from time to time! It
> > worked great ! thanks, maybe one day it can save a life, If i wanted
> > to run the query from the command line would i use the psql -c
> > run.psql to output a list to a txt file? im getting a error with that
> > ERROR: syntax error at or near "run" at character 1
> > LINE 1: run.psql
> > Thanks alot your time is very appreciated!
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
