[postgis-users] Custom CRS for a local survey grid
Mike Toews mwtoews at sfu.ca
Fri May 9 10:03:17 PDT 2008
Hi all,
I am working with spatial data that has been collected for the past
several decades at a site using a custom local coordinate system. I have
a few points at this site where I know both the local grid and the world
coordinates. Ideally, I'd like to define a custom srid to transform
between projections.
I would like to know more about adding new coordinate reference systems
to the spatial_ref_sys table, however I need to know a few things:
   1. Do I need to define all of: srid, auth_name, auth_srid, srtext,
      and proj4text fields in the spatial_ref_sys table? Or only a few
      fields (specify which are required or optional)?
   2. How would I define the projection for a local survey grid? (I may
      alternately ask this on the proj mail list)
At present, I have a spreadsheet to scale, translate and rotate points
to NAD83/UTM9N, or I use similar commands in CAD for drawings, but I
have much more work, and I'd like to make the translation more streamlined.
Any suggestions, answers, hints, or examples would be greatly appreciated.
Best regards,
-Mike
