[postgis-users] Does ST_AsText truncate or round
Havard Tveite havard.tveite at umb.no
Fri May 16 11:41:23 PDT 2008
Sorry, for not making much sense here.  What I wanted to
say was that ST_AsText(geom) should be equivalent to geom,
meaning that if you go from the database/binary
representation of the geometry to the text representation
of the geometry (using ST_AsText) and then back to the
database/binary representation (using ST_GeomFromText),
you should end up with the same geometry that you
started out with.  This is important for applications
that use when WKT when talking to PostGIS.
Håvard
Mark Cave-Ayland wrote:
> Håvard Tveite wrote:
>> ST_GeomFromText(ST_AsText(geom)) != geom
>> sounds like a bug to me (ignoring the SRS).
>> Håvard
> No, since the SFS 1.1 specification supports only 2 dimensions with no
> SRS (and ST_AsText() is spec compliant). If you need the SRS then you
> should use the PostGIS-enhanced ST_EWKT() function which will output the
> extra information, but is not spec-compliant.
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
