[postgis-users] Does ST_AsText truncate or round
Paragon Corporation lr at pcorp.us
Mon May 19 20:36:11 PDT 2008
Kevin,
Thanks.  This and Paul's comments helps to weight the pros and cons.
Well unfortunately I don't control the client application - but it will be
the same client application that is always used and since a lot of the
editing is done via javascript (custom open layers and GeoServer mix I think
- I'll have to find out more of the details of that to better weigh the
ramifications). I'm not quite sure how easy it will be to swing a WKB editor
in there or if that would be overkill.  It is not high precision stuff and
for the most part I think all the transformations have already been done
that will be.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Monday, May 19, 2008 10:57 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Does ST_AsText truncate or round
Hi Regina,
Sorry I didn't respond sooner ... I was out camping for the weekend.
Fun, fun :)
Right, this is what I was thinking with my previous post recommending
snaptogrid - force your geometries through WKT :
geomfromtext(astext(the_geom)).  Essentially, this would make all your
geometries only as precise as their WKT representation.  In a way, this
enforces a very fine precision model on all your geometries.  This should
elicit the data consistency you were after ... assuming of course that all
your table edits are performed using geomfromtext().  Bear in mind, though,
that if you have a client program that modifies the table using WKB, you may
be left with data in an inconsistent state.  If this is the case, put a
simple trigger on your tables forcing all UPDATES and INSERTS through WKT.
I agree with Paul R, however, that a client application should not be
transiting data using WKT, but rather WKB.  It may take some work, but I
would recommend that you upgrade your apps to perform all data edits using
WKB.
He was right when he mentioned that I fought with this for a while.  I had a
large database that utilized the full precision of PostGIS. I did some data
editing using a simple WKT editor and suddenly found that geometries that
used to touch no longer touch or they intersect incorrectly.
I guess it boils down to:
* A database that does not enforce any precision model, by default uses full
precision - thus, all data edits should be done using full precision.
* A database that enforces a precision model (including the one you
suggested where X = GeomFromText(AsText(X)) must be true), could be edited
using a editor with an equivalent precision model.  In your case, a WKT
enforced database could be edited using a WKT editor.  However, if you can't
guarantee that all editing is performed using WKT (including updating a
geometry using transform() ), then triggers should probably be constructed
enforcing the model on your spatial tables.
Cheers,
Kevin
Paragon Corporation wrote:
> Kevin,
> Actually this would help me with the second phase, but for the first
> phase I just need consistency which I was hoping AsText would do for
> me.  It doesn't even need to be that good since I'm sure the other
> side is using AsText in some fashion.  So I just need consistency more
than correctness.
> Where I start off with
> Orginal geometry X
> I think I need to guarantee that
> Seemed like the easiest way to assure that was to just force all my Xs to
X
> = ST_GeomFromText(AsText(X), somesrid)    which I presume should be the
same
> as
> ST_SetSRID(AsText(X), somesrid)
> The back end editor I'm assuming is just taking the AsText(geometry)
> representation and just returning that back when no edits on a
> particular point,  and so its being poisoned by its own database
> query.  I'm not working on that part so that's just my general
observation.
> Thanks,
> Regina
> Kevin Neufeld
> Sent: Friday, May 16, 2008 11:15 AM
> Have you considered using ST_SnapToGrid() and make all geometries in
> you database respect a specified tolerance?
> Warning, snaptogrid may not behave as you might expect - this is not a
> simple precision_reducer method (which I think would be valuable).
> Consider:
> select
>    'POINT(0.877 0.778)'::geometry ~=
>    snaptogrid('POINT(0.87689017271623 0.777984935324639)'::geometry,
> 0.001);
>   ?column?
>   t
> (1 row)
> No problem there, but then there's this:
> select
>    'POINT(0.956 0.66)'::geometry ~=
>    snaptogrid('POINT(0.956079571507871 0.659502930939198)'::geometry,
> 0.001);
>   ?column?
>   f
> (1 row)
> To deal with this (I know it looks like a hack, but it works), I
> convert to text and then back to a geometry.  Wrapping this in a
> trigger on your geometry tables will guarantee any geometry edits are
> automatically reduced to a certain precision.
> select
>     geomfromtext(astext(snaptogrid('POINT(0.956079571507871
> 0.659502930939198)'::geometry, 0.001)), -1);
>   ?column?
>   t
> (1 row)
> Cheers,
> Kevin
>> Slight clarification about what I am trying to solve.
>> After edits I am coming back with lines that used to be intersecting
>> no longer intersecting and that still have the same AsText
representation.
>> My hope is to reduce the precision of my geometry in the database so
>> the edits don't break the topology of my lines by doing something
>> like this
>> Update sometable
>> 	SET the_geom = ST_SetSRID(ST_AsText(the_geom), mysrid)
>> But I fear that if AsText is doing a rounding rather than a
>> truncation, that I run the risk of breaking things that used to
>> intersect.  I am more concerned about under intersecting than over
>> intersecting.  Although I probably haven't thought this out enough so
> maybe it's a non-issue.
>> Thanks,
>> Regina
>> Paragon Corporation
>> Sent: Friday, May 16, 2008 12:01 AM
>> To: 'PostGIS Users Discussion'
>> Subject: [postgis-users] Does ST_AsText truncate or round
>> Hopefully this is a simple question.  I know that ST_AsText returns a
>> geometry that is not necessarily as prescise as what is actually
>> stored in the geometry field.  I have an editor that relies on WKT
> representation.
>> Anyrate just wanted to know if the ST_AsText does a rounding of the
>> points or it does a truncation of the points.  Also would be nice to
>> know if I could control the precision of this since I will need to
>> truncate my actual geometry accordingly so that both are in agreement.
>> Thanks,
>> Regina
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
