[postgis-users] I'm missing something
Bob Pawley
rjpawley at shaw.ca
Tue May 20 13:12:59 PDT 2008
They are three lines that, on Quantum GIS, display as a flat U - a simple
tank. Using either tank_lin or process_dgn tables - exactly what I imported
using dxf2postgis.
'Select as text' returns three rows each with the expression
"Multilinestrings" followed by brackets and coordinates.
'Select St_Union' returns - unknown geometry error.
Are you thinking there is something wrong with the installation?
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, May 20, 2008 11:51 AM
Subject: RE: [postgis-users] I'm missing something
Are these big geometries? What does
SELECT ST_AsText(the_geom)
FROM tank_lin;
Also just to rule out its the table you are inserting into - does the
Union without inserting work?
Select ST_Union(the_geom)
from tank_lin;
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Tuesday, May 20, 2008 2:11 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] I'm missing something
Hi Regina
It gives me three rows each with the expression "ST_MultiLineString"
with nothing else.
Bob
From: Obe, Regina <mailto:robe.dnd at cityofboston.gov>
<mailto:postgis-users at postgis.refractions.net>
Sent: Tuesday, May 20, 2008 10:56 AM
Bob,
Strange. I don't think I have ever seen quite that error before.
What does
SELECT ST_GeometryType(the_geom)
FROM tank_lin;
give you?
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of
Bob Pawley
Sent: Tue 5/20/2008 1:07 PM
I tried this -
Insert into graphics.process_dgm(the_geom)
from tank_lin;
and got the error "Unknown geometry type: 0"
Bob
Sent: Tuesday, May 20, 2008 9:51 AM
> You don't want the GROUP BY. It is grouping the union op on
distinct
> geometry... ie, one per row. Remove it and you'll get what you
want,
> one output row.
> P
> On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca>
wrote:
>> Hi
>> I am attemptijng to use the ST_Union function to collapse
three rows from
>> a
>> table called tank_lin into one row in table called
process_dgm.
>> Here's what I used -
>> from tank_lin
>> Group by tank_lin.the_geom;
>> The result is three rows inserted into process_dgm, each row
appearing to
>> be
>> simple copies of each of the original rows.
>> I also attempted group by another column but received error
'unknown
>> geometry'.
>> I also tried STR_LineMerge with similar results.
>> What am I not considering?
>> Bob
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any
attachments, may be confidential, legally privileged and/or exempt from
disclosure pursuant to Massachusetts law. It is intended solely for the
addressee. If you received this in error, please contact the sender and
delete the material from any computer.
Help make the earth a greener place. If at all possible
resist printing this email and join us in saving paper.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
