[postgis-users] PostgreSQL/PostGIS and ArcGIS Server 9.3
Rob Tester
robtester at gmail.com
Fri May 23 09:14:21 PDT 2008
Okay, I have the current 9.3 rc1 with the SDE and PostGIS. I also have
talked with some of the developers at ESRI and can tell you the following.
Yes the support for PostGIS does exist. The geometries can be in WKB or SDE
(we keep ours in WKB). According to the developers of SDE for PostGIS there
isn't a large difference in the type anyway. But you can't use both at the
same time, so you have to pick your poison.
I have also patched ZigGIS so that it works with just the ArcGIS Engine
which is what we use to develop our applications.
Rob.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Chris
Hermansen
Sent: Friday, May 23, 2008 8:17 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL/PostGIS and ArcGIS Server 9.3
What I find immediately puzzling about this whole SDE - PostGIS thing is
a comment that Someone Knowledgeable (Paul? Martin?) made a few weeks
ago about an incompatibility between SDE's geometry and OGC or at least
PostGIS's implementation of OGC.
Sorry I can't provide more details, but does anyone recall this, and
have a comment on the matter?
Tim Bowden wrote:
> On Fri, 2008-05-23 at 09:29 -0500, Stephen Woodbridge wrote:
>> Tim Bowden wrote:
>>> Hi all,
>>> I've read bits and pieces about PostgreSQL/PostGIS and ArcGIS Server 9.3
>>> and how they (might) inter-operate. Can anybody point me to a concise
>>> summation of what's happening there? I understand ArcGIS Server will be
>>> able to use PostGIS geometries, but at what cost (performance and
>>> functionality)? Does this mean we can have ArcGIS and open source
>>> clients editing the same geometries?
>>> ArcGIS Server 9.3 beta is in the wild, and I've read that the final
>>> release is due "soon". Anyone have any idea if soon is measured in
>>> weeks or months?
>> Tim,
>> You might be interested in this link:
>> http://blog.davebouwman.net/2008/05/12/PostGISRound2ReadingTheManual.aspx
>> -Stephen Woodbridge
>> http://imaptools.com/
> Hot stuff, thanks Stephen. Looks very promising. With a bit of luck it
> will ease the transition to PostgreSQL/PostGIS for those wanting to go
> down that route. I can think of a few who will be looking at this over
> the next few years.
> Regards,
> Tim Bowden
> postgis-users mailing list
Regards,
Chris Hermansen mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 . fax+1.604.733.0631 . mob+1.778.232.0644
Timberline Natural Resource Group . http://www.timberline.ca
401 . 958 West 8th Avenue . Vancouver BC . Canada . V5Z 1E5
