[postgis-users] sync geometry with attributes
Matias Massigoge
matias.massigoge at agerpro.com.ar
Fri May 23 12:57:15 PDT 2008
John
I'think you need to define trigers in the updates of the table. In
this triguers you should update the fields inspecting the new value of
de Geometry.
Hope this help you.
Matías
On Fri, May 23, 2008 at 4:48 PM, John Callahan <john.callahan at udel.edu> wrote:
> Please excuse my question if it seems too trivial. I am just getting
> started with PostGIS and couldn't quite find what I was looking for.
> For a point data set, it is common for us to store the lat/long (or
> easting/northing) as attributes in the table. (Some programs we have require
> this.) However, when I edit the position through a GIS (like QGIS), the
> spatial location is altered but obviously not the attributes. And when
> these attributes are altered in the table, the geometry is not updated,
> obviously. Is there a way to keep these synchronized? Is this built into
> PostGIS?
> Thanks for your help. Even is you don't know how this could be done, is it
> possible?
> - John
> John Callahan
> Geospatial Application Developer
> Delaware Geological Survey
> University of Delaware
> 227 Academy St, Newark DE 19716-7501
> Tel: (302) 831-3584
> Email: john.callahan at udel.edu
> http://www.dgs.udel.edu
> postgis-users mailing list
