[postgis-users] srid
Andy Anderson aanderson at amherst.edu
Mon May 26 16:24:35 PDT 2008
On May 26, 2008, at 3:06 PM, Bob Pawley wrote:
> However, I attempting to interpret functions made for geographic
> data to use with geometric data.
> I have PostgreSQL tables which represent engineering processes.
> I want to display that data in a graphical form - hopefully using
> Postgis - - - if I can translate the functions (or the Postgis
> concept) into a form that I can use.
Hmmm... if all you want to do is display X-Y data, I would suggest
using geographic coordinates, e.g. SRID = 4326 (WGS84 datum), which
most programs will display by default with X and Y rectilinear.
However, you earlier said you wanted to use ST_Transform(geometry,
integer), which implies you want to switch between different
geographies.
So it sounds like you need to pick a particular projection for your
work.
Is your geography spherical or spheroidal? If so, you might want to
define your own datum. If not, you'll need to use a projection to a
flat surface. What's more important, that it be conformal
(equiangular) or equal area or that it preserve distance in one
direction?
-- Andy
