[postgis-users] Re: shp2pgsql (was "asKML")
Andy Anderson aanderson at amherst.edu
Tue May 27 15:41:55 PDT 2008
Re: "You have a misconception.  If it's a multipolygon in the shape
file, it will be a multipolygon in postgis. "
No misconception in that regard. The issue was that I expected there
to be a one-to-one feature correspondence, and it appeared that there
wasn't.
But digging further back in my work process, I did figure out the
issue. At one point I switched shapefiles from an ESRI-provided one to
a US Census-provided one, and the latter does actually have the state
polygons exploded into separate features. (Perhaps that's to allow it
work with less-sophisticated software, including older Arc versions.)
-- Andy
On May 27, 2008, at 5:26 PM, Paul Ramsey wrote:
> You have a misconception. If it's a multipolygon in the shape file, it
> will be a multipolygon in postgis.  When you open up the table view of
> your file in ArcView, how many rows are devoted to Hawaii? One, or 27?
> P
> On Tue, May 27, 2008 at 1:23 PM, Andy Anderson
> <aanderson at amherst.edu> wrote:
>> Sorry, that subject line should have been "shp2pgsql". That
>> question will
>> come later, I'm sure! :-)
>> On May 27, 2008, at 4:20 PM, Andy Anderson wrote:
>>> I've been working around one minor issue and it occurred to me that
>>> someone here might be able to explain the rationale for its design.
>>> I start with a shapefile of US states, which to me appears to be a
>>> set of
>>> multipolygons, one for each state. So, for example, Hawaii is a
>>> single
>>> multipolygon containing 27 polygons (at this scale).
>>> I then use shp2pgsql to produce a table of polygons, and Hawaii
>>> ends up as
>>> 27 multipolygons each containing one polygon!
>>> Is there a good reason for this? Or do I have a misconception
>>> about how
>>> Hawaii is being stored in the shapefile?
>>> Thanks,
>>> -- Andy
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
