[postgis-users] Roadmap for next major release of PostGIS
Chris Hermansen chris.hermansen at timberline.ca
Thu May 29 07:22:06 PDT 2008
Hi Mark;
If you look at
https://bugs.launchpad.net/ubuntu/+source/geos/+bug/139689 you will see
I suggested a GEOS upgrade back last fall - before 7.10 was released.
By the time the triage happened, I guess the Hardy decisions had been
made.  Unfortunately the clamour that reversed the decision on PostGIS
didn't pick up on GEOS as well.
Which gets back to my original comment - too bad PostGIS 1.3.3 builds
against GEOS 2.2.x :-)
Mark Cave-Ayland wrote:
> Chris Hermansen wrote:
>> Maybe (probably) I wasn't clear enough here.  I'm running Ubuntu
>> 8.04. The current versions in the repositories are:
>> PostGIS 1.3.3
>> Proj 4.6.0
>> Geos 2.2.3
>> PostgreSQL 8.3.1 (there's an 8.2 there as well)
>> I'm sad to see that a newer version of GEOS didn't make it to 8.04.  I
>> boldly assume that this is an easily-understood slip-up on the part of
>> the upstream folk that could have been averted had PostGIS refused to
>> build against (or at least complained about) Geos 2.2.x
> I'd say this is more of an error of the part of the Ubuntu packagers -
> GEOS 3 had previously been at RC stage for nearly a year, and the
> final release was back in December last year. In fact, it appears that
> the Ubuntu packagers even went as far as making PostGIS an exception
> to the feature freeze because of its importance:
> https://bugs.launchpad.net/ubuntu/+source/postgis/+bug/205179.
> Other than basic human error, the only thing I can think of is that
> another package somewhere in the GIS application bundle supplied with
> Hardy Heron still depends on GEOS 2.2.x series.
> ATB,
> Mark.
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
