[postgis-users] hexagonal grid
Sufficool, Stanley ssufficool at rov.sbcounty.gov
Thu May 29 13:21:02 PDT 2008
Generate a hexagonal grid of 64x128 hexes, then follow the slice/dice from bostongis at step 4.
Substitute the values in generate series with your datasource min/max X/Y extents.
create table hex_grid (gid serial not null primary key, the_geom geometry not null);
INSERT INTO hex_grid (the_geom)
SELECT translate(the_geom, x_series, y_series)
from generate_series(0 - 128, 10000 + 128, 128) as x_series,
generate_series(0 - 128, 10000 + 128, 256) as y_series,
	SELECT 'POLYGON((0 0,64 64,64 128,0 192,-64 128,-64 64,0 0))'::geometry as the_geom
	UNION SELECT translate('POLYGON((0 0,64 64,64 128,0 192,-64 128,-64 64,0 0))'::geometry, 64, 128)  as the_geom
) as one_hex
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matias Massigoge
Sent: Thursday, May 29, 2008 12:58 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] hexagonal grid
Thanks Paul!!
On Thu, May 29, 2008 at 4:42 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Try this:
> http://www.bostongis.com/blog/index.php?/archives/35-Map-Dicing-and-ot
> her-stuff.html
> P.
> On Thu, May 29, 2008 at 12:34 PM, Matias Massigoge
> <matias.massigoge at agerpro.com.ar> wrote:
>> Hi all,
>> I'm looking for something similar but squared.
>> This theme have been covered in the past?
>> Sorry, I'm newby.
>> Thanks all.
>> Matías
>> On Thu, May 29, 2008 at 12:42 PM, Brent Wood <pcreso at pcreso.com>
>> wrote:
>>>> On Thu, May 29, 2008 at 7:08 AM, Randall, Eric
>>>> <ERandall at eriecountygov.org>
>>> wrote:
>>>> > Has anyone created a method for generating a hexagonal grid over
>>>> > a polygon
>>>> envelope using postgis? Thought I'd ask before setting out.
>>>> Thanks.
>>> Hi Eric
>>> I haven't specifically done this in PostGIS, but have briefly looked
>>> into something similar with a colleague who uses R extensively, and
>>> was looking at cellular automata modelling over a hexagonal grid. He
>>> was using such a dataset in R, & there were a few ways this could be
>>> transferred to PostGIS, including the R:gdal package, or a
>>> dump/parse/reformat/import script.
>>> Cheers,
>>>   Brent Wood _______________________________________________
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> postgis-users mailing list postgis-users at postgis.refractions.net
