[postgis-users] Re: GeometryCollection Intersection
Markus Schneider
schneider at lat-lon.de
Fri May 30 08:14:19 PDT 2008
Hello again,
actually I wanted to ask about the "intersects" operator (and not
"intersection") which is used in the given example query.
Markus Schneider wrote:
> Hello,
> is it correct that geometric operations (especially intersection) are not
> available if one of the geometries is a GeometryCollection?
> My postgis_full_version() is:
> "POSTGIS="1.3.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004" USE_STATS"
> When I try to execute the following statement:
> SELECT X1.GEOM,X1.NAME,X1.ID FROM MULTITEST X1
> WHERE X1.GEOM && SetSRID('BOX3D(174259.098 487844.529, 177282.329
> 484821.298)'::box3d,28992)
> AND intersects (X1.GEOM, SetSRID('BOX3D(174259.098 487844.529, 177282.329
> 484821.298)'::box3d,28992))
> I get the error message:
> ERROR: Relate Operation called with a LWGEOMCOLLECTION type. This is unsupported
> SQL Status:XX000
> I already digged the source code a bit and found the apparent source of the
> message in lwgeom_geos_c.c. It's the check errorIfGeometryCollection(...).
> Is there any chance to perform an intersection between a Box and a
> GeometryCollection anyway? Or are there plans to implement this?
> Thanks in advance,
Best regards,
Markus Schneider
l a t / l o n GmbH
Aennchenstrasse 19 53177 Bonn, Germany
phone ++49 +228 18496-0 fax ++49 +228 18496-29
http://www.lat-lon.de http://www.deegree.org
On June 17 is deegree day - Am 17. Juni ist deegree day
http://deegree.org/deegreeday
