[postgis-users] How to tell if 2 geometries are spatially equal
Paragon Corporation lr at pcorp.us
Sat May 31 05:32:21 PDT 2008
Martin,
Yes that should do it.  I don't know how I missed that function.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Martin
Davis
Sent: Friday, May 30, 2008 7:54 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] How to tell if 2 geometries are spatially equal
Will ST_equals do what you want?  It reports whether two geometries are
topologically equal.
(So for example, ST_equals('LINESTRING(0 0, 10 10)','LINESTRING(0 0, 5 5, 10
10)') is true)
Obe, Regina wrote:
> I recall this having come up before.  I always thought that ~= would
> tell me if 2 geometries are spatially equal but it doesn't seem to.
> The only way I can figure to determine spatial equality is if
> ST_Within(A,B)  And  ST_Within(B,A)  (or ST_Difference(A,B) AND
> ST_Difference(B,A) both return an empty geometry collection)
> --So case in point
> SELECT geom1 ~= geom2 as what, ST_Within(geom1, geom2) AND
> ST_Within(geom2, geom1) As spatial_equal,
> 	ST_AsText(ST_Difference(geom1, geom2)) as diffgeom12,
> ST_AsText(ST_Difference(geom2, geom1)) as diffgeom21 FROM (SELECT
> 'LINESTRING(1 1, 1 2, 1 3)'::geometry As geom1,
> 	'LINESTRING(1 1, 1 3)'::geometry As geom2) As foo
> Results:
>  what | spatial_equal |        diffgeom12        |        diffgeom21
>  f    | t             | GEOMETRYCOLLECTION EMPTY | GEOMETRYCOLLECTION
> EMPTY
> Is there a function / operator that does that (also what does geom1 =
> geom2 compare - is it just bounding boxes or is that the spatially
> equal operator I am looking for?)
> Thanks,
> Regina
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
