[postgis-users] Union, but need to exclude any void
Toby Rainthorpe toby.rainthorpe at frsltd.co.uk
Sat Nov 1 01:37:29 PDT 2008
I have a list of territories, say 9 represented by a tic, tac, toe
board (3 x 3 grid ). A query selects all the outer perimeter (8
territories), but omits the central block. If i were then to union
this group the resulting polygon would fill, or include this central
block, even though I have not exclusively said that that territory has
been selected.
Is there a way of doing a union, or another method on a set of
polygons that will result in a polygon being created, but allow for
the void not to be included.
Thanks for your help,
Toby
SELECT
	GeomUnion(geom) as the_geom,
FROM (
	SELECT (dump(the_geom)).geom FROM territories WHERE
is_an_outer_territory = 1
