[postgis-users] Union, but need to exclude any void
Toby Rainthorpe toby.rainthorpe at frsltd.co.uk
Sat Nov 1 15:59:29 PDT 2008
Thanks for help, but it still looks like union fills in the gap so to
speak, any more ideas?
SELECT ST_AsEWKT(ST_Union(the_geom)) as the_geom
FROM postcode_sectors
WHERE postarea = 'LN'
"SRID=4269;POLYGON((0.194430850648443
53.213308161178,0.169714736355569 53.2124120839752,0.0834492984598471
53.2348844372266,0.0208307835734331
53.2478135975227,-0.0126938531249155
53.1710150547887,-0.13716904881661 53.1418544045366,-0.150749526290076
53.1243892073786,-0.130710137006856
53.0239835120991,-0.229285061035197
53.0038950480853,-0.338497757654447
53.0609112327498,-0.408675738441825 53.055621865059,-0.452241950934627
53.0579499714055,-0.52047527802287 53.0487392813369,-0.660214167307015
53.0546658032031,-0.714807399468163
53.0584148660486,-0.699290317426583
53.0756434022022,-0.716927624544292
53.1105928908201,-0.674018446595594
53.2187206490539,-0.668182682830745
53.2552110975952,-0.775752949336526
53.2466816979897,-0.764778898530289
53.2691344556123,-0.751456893012603
53.3202408495374,-0.567075865458079
53.3529438083222,-0.549064460589285
53.4257467252708,-0.461252440918993
53.4290079476242,-0.459280037729661
53.4356804144195,-0.491910432874966 53.497600359203,-0.41389940584748
53.5500565803702,-0.310449877650045
53.5267476031091,-0.219352544114183
53.5272954168687,-0.215026390840363
53.5063814691382,-0.203265094143773 53.466744705434,-0.122544300870874
53.4548941206983,0.0264268890418949 53.4620080919002,0.083849617015283
53.496544395631,0.228359151391426 53.408400422663,0.268028563946318
53.342544544341,0.302708719734213 53.2940795243504,0.321850405882593
53.2715163271867,0.234840151689661 53.1942224753385,0.194430850648443
53.213308161178))"
WHERE com_dist = 'LN1'
"SRID=4269;POLYGON((-0.567075865458079
53.3529438083222,-0.541250872030082 53.3316560575988,-0.53867243559146
53.2902048795337,-0.538372820842824
53.2545802514289,-0.536621729986015
53.2443903523506,-0.537587144360509 53.23365835124,-0.539261287526225
53.2285001962972,-0.542511758566372
53.2276409117944,-0.567956817933028 53.233334871246,-0.570638045173646
53.2342660459289,-0.574252637693809
53.2359726746639,-0.640114978977996
53.2538783112452,-0.668182682830745
53.3202408495374,-0.567075865458079 53.3529438083222))"
SELECT postarea, com_dist, gid
WHERE  postarea = 'LN' AND NOT com_dist = 'LN1'
ORDER BY postarea, com_dist
"LN";"LN10";4942
"LN";"LN10";4941
"LN";"LN11";4946
"LN";"LN11";4943
"LN";"LN11";4944
"LN";"LN11";4945
"LN";"LN12";4947
"LN";"LN12";4948
"LN";"LN13";4949
"LN";"LN13";4950
"LN";"LN2";4912
"LN";"LN2";4914
"LN";"LN2";4915
"LN";"LN2";4913
"LN";"LN2";4916
"LN";"LN3";4918
"LN";"LN3";4917
"LN";"LN4";4922
"LN";"LN4";4920
"LN";"LN4";4919
"LN";"LN4";4921
"LN";"LN5";4926
"LN";"LN5";4923
"LN";"LN5";4924
"LN";"LN5";4925
"LN";"LN6";4927
"LN";"LN6";4932
"LN";"LN6";4928
"LN";"LN6";4929
"LN";"LN6";4931
"LN";"LN6";4933
"LN";"LN6";4930
"LN";"LN7";4934
"LN";"LN8";4937
"LN";"LN8";4936
"LN";"LN8";4935
"LN";"LN8";4938
"LN";"LN9";4939
"LN";"LN9";4940
Subject: 	RE: [postgis-users] Union, but need to exclude any void
Date: 	1 November 2008 19:23:09 GMT
To: 	postgis-users at postgis.refractions.net
Reply-To: 	postgis-users at postgis.refractions.net
Toby,
I agree with Stanley that it is probably not a ST_Union problem.  I'm
guessing there is something wrong with your WHERE clause.  Keep in
mind PostgreSQL is case sensitive so if by chance
you had something like ln1  instead of LN1 in the com_dist field, then
the ln1s would be picked up as NOT ....
To rule out ST_Union as the culprit, can you do a simple attribute query
Also I tend to do com_dist <> 'LN1' , but that shouldn't matter.
Hope that helps,
Regina
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081101/6b66c311/attachment.html>
