[postgis-users] WKT polygon and interior ring orientation
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 3 10:18:03 PST 2008
Since PostGIS explicitly keeps track of whether a ring is exterior or
interior, the orientation is neither here nor there. Internally I
think it matters not at all. For ST_As*() functions, I can see
enforcing orientation as a useful thing, since that would remove the
need for clients to do so post-facto, if they happen to have their own
orientation requirement. On the other hand, if a client inserts a
non-oriented polygon and then gets it back orients, that violates the
principle of "minimal screwing with people's data" that we are trying
to hew to.
P.
PS, here's a quick proof that we currently don't care:
pramsey=# select st_astext(st_geometryfromtext('POLYGON((0 0, 0 10, 10
10, 10 0, 0 0), (5 5, 5 6, 6 6, 6 5, 5 5))'));
st_astext
POLYGON((0 0,0 10,10 10,10 0,0 0),(5 5,5 6,6 6,6 5,5 5))
(1 row)
PPS, and here's an enforced version:
pramsey=# select st_astext(st_forcerhr(st_geometryfromtext('POLYGON((0
0, 0 10, 10 10, 10 0, 0 0), (5 5, 5 6, 6 6, 6 5, 5 5))')));
st_astext
POLYGON((0 0,0 10,10 10,10 0,0 0),(5 5,6 5,6 6,5 6,5 5))
(1 row)
PPPS, this raises an interesting code-trawling exercise, to see if we
have a surfeit of "is this ring oriented" tests in our functions,
since if we do, then orienting at load time would be a time saver
later on.
On Mon, Nov 3, 2008 at 9:34 AM, Tara Athan <tara_athan at alt2is.com> wrote:
> My apologies for not stating my question clearly. I am not questioning
> whether polygon orientation must be counter-clockwise or clockwise- it is
> clear from the specs, v1.2.0 at least, that either is acceptable, although
> the result would be a change in the normal to the surface.
> However OGC v1.2.0 part 1 does make it clear that the interior rings should
> be oriented in the "opposite" direction as the the exterior rings. This
> would be consistent with a RHR convention because when traversing a hole the
> RHR would cause the switch from clockwise to counter-clockwise, or v.v.
> The question them becomes- does the software implement this convention? If
> there is no error in the PostGIS documentation, then the example of a
> polygon with a hole
> POLYGON((0 0,4 0,4 4,0 4,0 0),(1 1, 2 1, 2 2, 1 2,1 1))
> that is given in the PostGIS documentation would appear to violate the OGC
> v1.2.0 as well as the RHR (or the LHR).
> Or perhaps it is a typo.
> But surely it matters?
> Tara
> Kevin Neufeld wrote:
> If you look at the OGC spec v.1.1.0 and the current v1.2.0, Part 2, the only
> reference to orientation is in a footnote, "Polygon rotation is not defined
> by this specification; actual polygon rotation may be in a clockwise or
> counter-clockwise direction."
> Prior versions don't even mention orientation.
> http://www.opengeospatial.org/standards/sfs
> It's my understanding that polygon orientation doesn't really matter and
> even varies from one database vendor to another. Martin Davis may be able
> to answer the whys better, but since the specs didn't specify at the time, I
> believe JTS/GEOS chose to follow the somewhat more accepted orientation and
> follow the Right-Hand-Rule - that is, the orientation of the rings are such
> that the thing they are bounding is to the right. In particular, an
> exterior ring is clockwise and interior rings are counter clockwise.
> PostGIS even has a forceRHR for polygons ... but like I said, I don't think
> it really matters.
> -- Kevin
> Tara Athan wrote:
> Noobie question here:
> I am trying to understand WKT so I can build my own polygons from GPS points
> for entry by SGL commands. In reading the OGC specification
> http://portal.opengeospatial.org/files/?artifact_id=18241
> I thought I understood it to say that interior rings should have a clockwise
> orientation,
> "6.1.11.1 Description
> A Polygon is a planar Surface defined by 1 exterior boundary and 0 or more
> interior boundaries. Each interior
> boundary defines a hole in the Polygon. A Triangle is a polygon with 3
> distinct, non-collinear vertices and no
> interior boundary.
> The exterior boundary LinearRing defines the "top" of the surface which is
> the side of the surface from which the
> exterior boundary appears to traverse the boundary in a counter clockwise
> direction. The interior LinearRings will
> have the opposite orientation, and appear as clockwise when viewed from the
> "top", "
> but the example given in the PostGIS documentation
> http://postgis.refractions.net/documentation/manual-1.3/ch04.html#RefObject
> gives an interior ring with counter-clockwise orientation. Am I missing
> something?
> Thanks, Tara
> postgis-users mailing list
> ________________________________
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.8.5/1759 - Release Date: 10/31/2008
> 4:10 PM
> My e-mail delivery has been unreliable lately, so I am asking for
> return receipts from all my email messages.
> OK'ing the return receipt lets me know that my message was delivered.
> Thank you.
> Tara Athan
> Principal, Alternatives to Invasive Species
> tara_athan [AT] alt2is.com
> 707-485-1198
> PO Box 415
> Redwood Valley, CA 95470
