[postgis-users] gis noob question
Iulian Margarintescu eti at erata.net
Tue Nov 4 07:16:29 PST 2008
I have a collection of shapefiles for a number of zipcodes witch i
already imported to postgres, and with i need to use them to create a
map with ThinkGeo. Loading all the data in ThinkGeo (the same in uDig)
works but really slow ( also slow when loading shapefiles directly ).
After some research i've found out about simplification algorithms and
at first tried to simplify every shape for every zipcode but when
displayed there are a lot of gaps between shapes. Than i've found out
about topology preserving simplification but i does not make a lot of
sense to apply the algorithm for each shape, and if applyed for a
collection of shapes it would be nice if after the simplification i
still have a shape for each zipcode since i have data attached to the
zipcodes.
Now my question is how should i apply this topology preserving
simplification?
Is it sane to do something like this (with a lot of zipcodes):
select geom(st_dump(
    (select  ST_SimplifyPreserveTopology ( st_collect(the_geom),0.01)
from zipcodes
Any other ideas on how should i approach this ?
