[postgis-users] gis noob question
Martin Davis
mbdavis at refractions.net
Wed Nov 5 11:58:12 PST 2008
You're partly right, Regina. Simplifypreserve does work on a collection
basis. However, it is designed to prevent overlaps from occuring, but
not "non-overlaps". So even if you collect the polygons into a
GeometryCollection, gaps can still occur - this doesn't violate the
notion of "topology" that is preserved by simplifypreserve.
One way to prevent gaps from happening between coincident linestrings is
to reduce them to a single linestring. So to simplify a coverage of
polygons, it should be possible to dissolve them into a single-line
coverage as a MultiLineString, simplify that, and then polygonize the
result.
I haven't tested this, but that's the theory...
Paragon Corporation wrote:
> The reason I say no is that that if you collect the geometries first and
> then simplify, I think even simplifypreserve will loop thru each geometry
> anyway and simplify. Though I'm not absolutely positive of that. So the
> whole exercise of collect simplify dump is a bit fruitless if that was your
> intention. Not a bad thought and maybe you are right so maybe someone can
> correct me on that.
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
