[postgis-users] Strange problem with &&
Paragon Corporation lr at pcorp.us
Fri Nov 7 19:40:10 PST 2008
Mark,
If I do a BOX3D check, the answers agree.  I assume that is because only the
box2d is cached and the BOX3D is always calculated from scratch?
So it does seem to be a trigger issue interfering with the cache_box logic.
The only geometries affected as afar as I can tell are those moved as a part
of the triggers.
I thought I had fixed it, but turns out moving my first trigger to be an
after just allowed me to fix the defective cached boxes but the problem
still continues as people move things.
I have a transaction log table that keeps track of trigger edits - and doing
a sampling of one
SELECT ST_Box2D(ST_AsHexEWKB(old_the_geom)) As old_calcbbox,
ST_Box2d(old_the_geom) As old_storedbbox,
ST_Box2d(the_geom) As new_storedbbox, ST_Box2D(ST_AsHexEWKB(the_geom)) As
newcalcbbox , ST_Box3D(the_geom) As new3dbox
FROM us.edge_trans WHERE trans_id = 446
---See how the stored bbox is the same as what the original was before the
move.
Old_calcbox: BOX(-9735475 5010606,-9735186 5010845)
Old_storedbox: BOX(-9735475 5010606,-9735186 5010845)
New_storedbox: BOX(-9735475 5010606,-9735186 5010845)
New_calcbox: BOX(-9735475 5010606,-9735172 5010845)
New_3dbox BOX3D(-9735474.33497473 5010606.13458183 0,-9735172.74302071
5010844.6196023 0)
So I guess maybe I'll try just have to put in yet another step at the end
that sets a new bbox if the cached is wrong.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Friday, November 07, 2008 9:54 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Strange problem with &&
Paragon Corporation wrote:
> I thought maybe this was a bug in GIST from before my upgrade, so I
> dropped my gist index on the affected table and readded it and still
> get the same bizarre behavior.
Hi Regina,
Does changing ST_box2d() to ST_box3d() help at all?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
